Mouse Problem
AnnoyedMouse
If this is in the wrong section, could it be moved to the right one please, thanks
Im having a problem with my mouse, it started a couple of days ago, it keeps sticking for about 5 seconds at a time and a "bink" sound starts as if its trying to find it, i cant do anything with the mouse at all.
Occationally in the bottom right corner a symbol comes up with
"One of the USB devices attached to this computer has malfuctioned and Windows does not recognise it
The location of the device is shown in bold type"
The problem is there is nothing in bold type, its getting really annoying now
Ive cranked up Norton and theres no viruses ect on my comp
Details
Laptop (2 months old)
Optical mouse, bought at same time as laptop
Vista 32
Thanks for any help
what is the laptop model and the mouse??
are you using an OEM os (meaning it was already installed with your laptop)??
is there by any chance dust in your usb ports???
can you also provide a screen shot of your device manager ???
I dont know much about comps but here goes
Compaq Presario
CQ50-110EM
Notebook PC
On the Optical Mouse it says
PC / LINE
PCL - WS01
5V 100mA
The operating system was pre installed when i got it
How do you take screenshots?, also what part of the device manager?
right click my computer and click properties....
click on the device manager...
on the keyboard there should be a print screen key....
press it then open paint....
paste and save it and post it here...
Ive opened the Device Manager, im trying to print screen, it does not want to do it as i go to paint and go to edit and it wont "paste"
Found the Print screen button, went to device manager, pressed it, went to paint, new, edit and no paste
Is there anything in device manager which i should be looking for?
The pages slightly overlap but i hope this helps
when it happens check back with the screens of the error
also when the mouse is unrecognized can you show me the device manager again
there should be a item with an exclamation point
can you click and can save a screenshot of that...
also when that happens i will give other instructions
when the error happens do not do anything.....
also record the time when it happens....
Hi
Its started doing it again, it was fine for about an hour/hour half last night but has started up again today :( , theres been no error message come up yet - even then it only came up a few times - and there is no problem on the device manager i can see, all the drivers say up to date
When it happens the Hour glass apears next to it
It could be that your mouse is simply ceasing to work properly, or is only working intermittently. Have you tried an alternative mouse?
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Iomega 1.5TB Ext USB 2.0
    WD 2.0TB Ext USB 3.0
    Gigabyte IF233
now trying a new one, ill see how this one goes, probebly is the mouse even though it is less than 2 months old :(
Looks that was the problem, always the simplest thing
I'm glad that you have solved your problem. Remember the first rule of problem solving: Don't overlook the obvious.
    Gigabyte IF233
