Go Back   Vista Forums > Vista Forums > General Discussion
Vista - Mouse Problem
Old 01-03-2009   #1 (permalink)
vista 32
Mouse Problem
If this is in the wrong section, could it be moved to the right one please, thanks
Im having a problem with my mouse, it started a couple of days ago, it keeps sticking for about 5 seconds at a time and a "bink" sound starts as if its trying to find it, i cant do anything with the mouse at all.
Occationally in the bottom right corner a symbol comes up with
"One of the USB devices attached to this computer has malfuctioned and Windows does not recognise it
The location of the device is shown in bold type"
The problem is there is nothing in bold type, its getting really annoying now
Ive cranked up Norton and theres no viruses ect on my comp
Details
Laptop (2 months old)
Optical mouse, bought at same time as laptop
Vista 32
Thanks for any help
Old 01-03-2009   #2 (permalink)
Server 2008 R2 , Windows 7 6801 + 6936 x64,6801 6956 x32, Windows Home Premium Sp1 x64, Linux
Re: Mouse Problem
what is the laptop model and the mouse??
are you using an OEM os (meaning it was already installed with your laptop)??
is there by any chance dust in your usb ports???
can you also provide a screen shot of your device manager ???
Old 01-03-2009   #3 (permalink)
vista 32
Re: Mouse Problem
I dont know much about comps but here goes
Compaq Presario
CQ50-110EM
Notebook PC
On the Optical Mouse it says
PC / LINE
PCL - WS01
5V 100mA
The operating system was pre installed when i got it
How do you take screenshots?, also what part of the device manager?
Old 01-03-2009   #4 (permalink)
Re: Mouse Problem
right click my computer and click properties....
click on the device manager...
on the keyboard there should be a print screen key....
press it then open paint....
paste and save it and post it here...
Old 01-03-2009   #5 (permalink)
vista 32
Re: Mouse Problem
Ive opened the Device Manager, im trying to print screen, it does not want to do it as i go to paint and go to edit and it wont "paste"
Old 01-03-2009   #6 (permalink)
Re: Mouse Problem
Print screen - Wikipedia, the free encyclopedia
look for these word in a certain key Prt Scr, Print Scrn, Prt Scn, Prt Sc or Prnt Scrn
i believe you have to press the Fn key...
as this is a keyboard....
it is usually by the insert key...
Old 01-03-2009   #7 (permalink)
vista 32
Re: Mouse Problem
Found the Print screen button, went to device manager, pressed it, went to paint, new, edit and no paste
Is there anything in device manager which i should be looking for?
Old 01-03-2009   #8 (permalink)
Re: Mouse Problem
since this is a laptop did you press the Fn key??
Old 01-03-2009   #9 (permalink)
vista 32
Re: Mouse Problem
The pages slightly overlap but i hope this helps
Old 01-03-2009   #10 (permalink)
Re: Mouse Problem
i dont see any conflicts...
hmmm....
was the mouse plugged in??
MOUSE PROBLEM Vista General
Mouse problem General Discussion
Mouse Problem Vista hardware & devices
Help me: mouse problem Vista General
Mouse problem Vista General
