| | #11 (permalink) |
| Home Premium 32bit | Re: System Restore problem Hello, I have 3 PC;s running Windows Vista. I have many times to use system restore and have NEVER once had it complete sucessfully. So just to let you know that you are not the only one that can't get it to work. Wish I had an answer for you but I do not. Regards: Bobby |
| | #12 (permalink) |
| Vista Home Premium 32bit SP1 | Re: System Restore problem USB keyboard support was already enabled, but I took the opportunity to enable USB mouse support as well. After that F8 worked and I was able to get to the safe mode menu. The issue I had that led me to consider System Restore has now resolved itself, but at least I should now be able to get there if it happens again. I still don't understand why System Restore will not work from within normal Windows, as the "Windows Vista Bible" says that it should. |
| | #13 (permalink) |
| Vista Ultimate | Re: System Restore problem Glad you sorted this out. Cheers |
| | #14 (permalink) |
| Vista Home Premium x64 | Re: System Restore problem USB keyboard support was already enabled, but I took the opportunity to enable USB mouse support as well. After that F8 worked and I was able to get to the safe mode menu. The issue I had that led me to consider System Restore has now resolved itself, but at least I should now be able to get there if it happens again. I still don't understand why System Restore will not work from within normal Windows, as the "Windows Vista Bible" says that it should. |
| system restore Problem | General Discussion | |||
| System Restore Problem | General Discussion | |||
| System Restore problem | Vista General | |||
| problem with system restore | Vista General | |||
| System Restore Problem? | Vista General | |||
