need help with a multi boot experiment
bossmayank619
[FONT=&quot]Is it possible to install 6 Linux distros with windows vista and windows 7 with vista as main OS and use Vista bootloader for all of them by using EASY BCD. disstros trying to use are windows vista , windows 7 beta, ubuntu , fedora 10 , mandriva , pclinuxos , linuxmint and opensuse. crazy but just trying something new thats how i like to learn things. :shock::shock::shock::shock:[/FONT]
    Hp DV 6137 TX
    Nvidia GeForce 7400
I'd say it would be possible. Not easy, but possible ;)
I've never tried that many Linux distros at once, but have had a quad-boot of XP, Vista, Ubuntu and Opensuse playing nicely in the past. All tidied up with Easy BCD.
Once you have all OS'es installed and point Easy BCD to to all relevant GRUB loaders, you should be fine.
Hell of an experiment though :p
    i7 3770K HT ON 4.7GHz
    P8Z68 Deluxe Gen 3
    8GB G.Skill Ripjaws X 2133mhz
    X-FI Forte + ATH-AD900
    1920*1200 / 1920x1080
    Corsair AX1200W
    Lian Li PC-V1020A
    Laptop Specs:
    Clevo Sager P170HM //
    17.3 Matte 1920x1200 //
    i7 2720QM // 8GB 1333mhz //
    Dedicated GTX 485M //
    Samsung Story 2TB USB 3.0
Hey this is wat i've been tryin'..... bt didn't rely work for me.... it's says cannot find boot...... can u help..... and be more specific.
THANK You
