PLEASE HELP! Plugged in, not charging?
  1. #1
    ComputerAge's Avatar
    h@cker
    New York
    Mac OS X 10.6.5 Snow Leopard
    Local Time: 09:46 PM
    usa us new york
    I have had it with Vista. Out of all the 6 computers I have had, this is my only one with Vista and to tell you the truth, this has had the most problems. This never happened to me since recently. Whenever I plug in my computer to AC power, it shows as plugged in, not charging. I take it out for a while to cool it down, and then after about 15-20 minutes I put it back in, and it shows as fine. When I scan it with HP Battery Check (during "plugged in, not charging") it shows as "Replace Battery". When I scan it after I fix the problem (plugged in, charging) it shows as "Good". Then after approximately 2 hours it again shows as plugged in, not charging. Does anybody know why?
    Thanks,
    RF
    P.S. I am still under parts and labor warranty, just in case.
  2. #2
    Brian the King's Avatar
    Windows Vista Home Premium x64 SP2
    Local Time: 08:46 PM
    usa
    Re: PLEASE HELP! Plugged in, not charging?
    Quote Originally Posted by Computer Age View Post
    ...I am still under parts and labor warranty, just in case.
    Go for that.. not sure there's anything you can do yourself.
  3. #3
    Brink's Avatar
    Administrator
    Texas, USA
    64-bit Vista Ultimate SP2, Windows 7 Ultimate SP1, Windows 8 Enterprise
    usa us texas
    Hello RF,
    It can be a number of things wrong. You could have a bad battery, battery loose, bad charger, bad charger connection to laptop, battery to hot to allow to charge.
    Since you are still under warranty, you should have them take a look at it to have anything replaced as needed. With the HP Battery Check results, I would lean towards a defective battery though.
    Hope this helps some,
  4. #4
    h@cker
    New York
    usa us new york
      Thread Starter
    Quote Originally Posted by Brink View Post
    Hello RF,
    Thanks guys, will continue to try all the recommendations. I have already contacted HP when I thought it was the AC adapter and the are sending me a replacement. Then today I chatted with them and asked for a new battery. They said they would send it to me but I would first have to try the AC adapter. If it works with the new AC adapter, they will not send the battery but if it doesn't work they will send me a battery. If that doesn't work they will follow-up. It might be a loose charging circuit on the motherboard, but as I said I am under warranty. Worst comes to worst I replace the laptop (again). I tried uninstalling and reinstalling the ACPI but it didn't work. Oh well!
  5. #5
    Brink's Avatar
    Administrator
    Texas, USA
    usa us texas
    Well at least it looks like they are going to take care of you on this.
  6. #6
    h@cker
    New York
    usa us new york
      Thread Starter
    I guess so.
  7. #7
    Brink's Avatar
    Administrator
    Texas, USA
    usa us texas
    Please let us know how it turns out.
  8. #8
    h@cker
    New York
    usa us new york
      Thread Starter
    Guess what! I got my new AC adapter today in the mail and I plugged it in and it worked fine! It is continuing to work! I guess it was a loose charging pin in the AC adapter! Thanks anyway for your help
  9. #9
    Brink's Avatar
    Administrator
    Texas, USA
    usa us texas
    Computer Age,
    I'm happy to hear that it seemed to have sorted it out for you.
  10. #10
    h@cker
    New York
    usa us new york
      Thread Starter
    I have one more quick question. Once, my friend accidentally put his MS Duo in my slot instead of MS Pro. I got it out, but now it is damaged. The drivers are right, and a light near the slot lights when a card is in. When I put my cards in, it doesn't show, and the light isn't there. When I play with the card, pushing it in and out, the light sometimes goes on but then immediately goes off. What should I do?
Page 1 of 2 12 LastLast
PLEASE HELP! Plugged in, not charging? problems?
battery plugged in, not charging jennifer b Vista hardware & devices 6 15 May 2010
Plugged In, Not Charging Battery Ted Vista hardware & devices 19 10 Aug 2009
Battery plugged in, not charging pigeon-wing Vista hardware & devices 2 20 May 2009
98% Plugged in, not charging. Rathman General Discussion 5 05 Nov 2008
"Plugged In, Not Charging" allison_wonderland Vista General 1 18 Jul 2008
