Go Back   Vista Forums > Vista Forums > General Discussion
Vista - Laptop Battery Wont Charge
Old 04-09-2009   #1 (permalink)
Vista Ultimate x64
I am using a HP Laptop, 6314tx. It has been 1 year and 9 months since I am using it. In the past couple of months, I have experienced a battery problem. My laptop battery doesn't charge more than 33%. It was 67% first, then came down to 43% and now 32%. Sometimes, it shows '100% available (plugged in, charging).' But, when I click on the battery icon, it again shows as '32% available (plugged in, charging).'
Is there any solution to this?
Old 04-10-2009   #2 (permalink)
Re: Laptop Battery Wont Charge
Hello Mrigankp,
You might use this HP battery test to see what the health of your battery is. It may be time to get a new battery or charger. You can read more about this test here.
Hope this helps for now,
Old 04-10-2009   #3 (permalink)
Vista Ultimate x64
Hey Brink. Thanks for the link. I downloaded HP Battery Test software. I clicked on the exe file and ran the setup. But, after the setup is complete, I don't see anything on my screen. I also checked in 'programs.' What could be the problem?
Old 04-10-2009   #4 (permalink)
Not sure, but this is what they say:
The Battery Check utility can be launched by clicking Start > Control Panel > HP Battery Check or by clicking Start > Hewlett-Packard > HP Battery Check
Old 04-10-2009   #5 (permalink)
Vista Ultimate x64
I restarted my computer and the software started working. It says that the battery's health is weak. I need to replace my battery. But, I don't understand one thing, why the does the battery indicator sometimes shows '100% Available, Plugged In, Charging?'
Anyway, thanks for your help.
Cheerz!
Old 04-10-2009   #6 (permalink)
It's normal to get fluctuating results like that when the battery is failing. Sometimes it will be just fine, while most of the time it will not be.
Old 04-10-2009   #7 (permalink)
Vista Ultimate x64
Thank you for your help.
Old 04-10-2009   #8 (permalink)
You're welcome Mrigankp. I'm sorry to hear that you battery is in bad health.
Old 04-10-2009   #9 (permalink)
Vista Ultimate x64
Oh well, it was going to happen sooner or later. I am thinking of buying a 12-cell battery. It is said that it gives a 3.5+ hours on 'high performance.'
Old 04-10-2009   #10 (permalink)
That's not bad at all with high performance.
Help needed - laptop battery will not charge General Discussion
My Battery doesnt charge Vista performance & maintenance
Vista RC1 will not charge battery Vista hardware & devices
Laptop battery won't charge after Vista installed Vista hardware & devices
how to charge a battery Vista hardware & devices
