Intel E8400 Temp problem
  1.    10 Apr 2009 #11
    Lancaster University, England.
    Windows 7 Professional X64
    Local Time: 05:11
    england
    Re: Intel E8400 Temp problem
    I think there might be something wrong with the sensors. -27c min temp?
    Is it a pre-built computer or did you build it yourself?
    I had a lot of incorrect readings on my old Dell PC. I had motherboard temps of -100c.
  2.    10 Apr 2009 #12
    Riyadh
    Windows 7 Ultimate x64
    Local Time: 08:11
    saudi arabia
      Thread Starter
    hMM OK brothers Thx for a good piece of advance. I want to know 1 thing more. Does overheated pc (liek mine sadly) is slower then normal. I notice my GTA4 is laging even on low setting. B4 it work like charm on High settings.
  3.    10 Apr 2009 #13
    Riyadh
    Local Time: 08:11
    saudi arabia
      Thread Starter
    I build it myself
  4.    10 Apr 2009 #14
    Local Time: 05:11
    england
    Overheated components will begin to throttle themselves, so yea it can result in slower performance.
  5.    10 Apr 2009 #15
    stew2 Guest
    In cpu-z it shows your running at 1995mhz. With the temps your posting id imagine your pc always runs at that speed and never goes up to the 3Ghz it should.
  6.    10 Apr 2009 #16
    Riyadh
    Local Time: 08:11
    saudi arabia
      Thread Starter
    Its running at 1995mhz coz intel speedstep is not disabled.
  7.    10 Apr 2009 #17
    stew2 Guest
    Yeah but its supposed to go up to 3Ghz when you do something like play a game. But in your case id think it wouldnt or at least wouldnt stay there for long as your so close to max temp already that it would throttle your performance so as to avoid damaging the cpu, getting blue screens of death, crashes etc.
  8.    10 Apr 2009 #18
    Riyadh
    Local Time: 08:11
    saudi arabia
      Thread Starter
    @stew: There were too much dust stroms in my city.
    See here Saudi Arabia’s Giant Sandstorm | Shareordie
    After this strom i didnt clean my pc. So cleaning pc will solve sensor problems?
  9.    10 Apr 2009 #19
    stew2 Guest
    WOW. If i was you id move .
    But anyway you should clean out your pc just to make sure. Make sure to remove all dust from fans, heatsinks, the motherboard etc.
    I dont think all your sensors have gone bad, but clean the pc and if you know how to then you should probably re-apply thermal paste to the cpu and install the heatsink and fan.
    Make sure to route all cables as neatly away as possible as well and if possible install more fans.
  10.    10 Apr 2009 #20
    Riyadh
    Local Time: 08:11
    saudi arabia
      Thread Starter
    Tonight I'll clean the pc and tomorrow morning i'll get a new cpu fan and case fans. Thx alot for ur help bro.
Page 2 of 5 FirstFirst 1234 ... LastLast
Problem with temp files
Hi, I am using Vista-32bit, and when i start instaling software or even downlad something big, i got the message that there is no enough space and...
General Discussion
OCing e8400 with asus mobo
complete noob..... in an article on this forum about ocing an intel 8400 on a asusp5n-t deluxe stew2 advised "go to your tweaking tab and set the...
General Discussion
Max overclock with E8400
Hi guys, I have an Core 2 duo E8400 @ 4GHz and i'm wondering what is the max speed it can be over-clocked to.
General Discussion
Windows Vista strange settings on temp folder AppData\Local\Temp\1
First off, i am trying to figure out what causes my temp folder to move from AppData\Local\Temp to AppData\Local\Temp\1. When i log out and log...
Vista security
Successful OC e8400 @ 4.00Ghz
Here are the settings i managed to get my E8400 to run stable at 4.00Ghz with ram at 890Ghz. Sytem Clocks: PCIEX16_2: 100 MHz PCIEX16_1: 100 Mhz...
General Discussion
help OC'ing E8400 with ASUS Mobo
Ok here's the story. I have the Intel Core 2 Duo E8400 running at 3.00Ghz. I would like to run it at 3.75Ghz stable...and be able to run it at...
General Discussion
Intel E8400
Hello guys hope u all doing good. Guys i've intel e8400 3.0ghz but it is running only 2ghz. is that normal???
General Discussion
Our Sites
  • Ten Forums
  • Eight Forums
  • Seven Forums
  • Help Me Bake
  • Site Links
  • Contact Us
  • Privacy and Cookies
  • Old server
    About Us
    Windows Vista Forums is an independent web site and has not been authorized, sponsored, or otherwise approved by Microsoft Corporation. "Windows 10" and related materials are trademarks of Microsoft Corp.
