Solved Problem with the thumbnail preview.. help!!!
pramodm
HELLO GUYS,
I'M FACING A BAD PROBLEM..
Is der a way dat i cn change de thumbnail preview of the images formats like jpeg an all other pictures.. i tried setting de defaults to picasa an so on.. bt de problem s dat t shows de pictures as filmstrip thumbnails.. since i do alot of movie editing an stuff i hav been used to using de thumbnail preview since de windows xp.. bt since t shows all de movies an even de pictures along with t as filmstrip thumbnails by default it sure causes me alot of confusion as to which one s which..
I GUESS U HAVENT UNDERSTOOD MY PROBLEM.. PLS HAV A LOOK AT DE PICTURE..
THE PROBLEM IS DAT DESE R SUPPOSED TO B DE THUMBNAILS FOR VIDEOS AND DIS S NOT HOW DE PICTURES R PREVIEWED IN DE WINDOWS VISTA..
SIR DESE R JPG PICTURE FILES.. DEY R BEING DISPLAYED AS MOVIE FILES.. SEE DE FILM STRIP ON EITHER SIDES OF DE PICTURE?? DID WAS NOT HOW IT USED TO BE IN DE ORIGINAL WINDOWS VISTA..
HAVE U UNDERSTOOD MY PROBLEM?? IF NOT I SHALL GIV U MORE DETAILS.. DO U ALSO HAVE DE SAME PROBLEM??
THANKN U FOR LOOKIN INTO MY PROBLEM..
PRAMODM..
Hi pramodm.
Can you write correctly please? It's very hard to understand what you write...
    AMD Athlon 64 X2 6400+
    Asus M2N-E SLI
    2 x NVidia 8600 GTS
    Integrated CM-6501
    Benq 19" + LG 17"
    1280x1024@32bit@75MHz
    1 x Seagate 120GB SATA (OS installation)
    1 x Seagate 200GB SATA
    2 x Seagate 320GB SATA (Hardware RAID 0)
    1 x Seagate 250GB IDE (in external USB box)
    1 x TrekStor 750GB USB
    650W
    Logitech Cordless Desktop EX 100
    Logitech Cordless Optical
    8192 kbps / 640 kbps
Yes sir,
so sorry about de shortcut words..
Pls hav a look at my picture..
The problem is that these thumbnails are supposed to be de thumbnails for videos..
But dese r actually jpeg pictures.. Dey r being displayed as movie file THUMBNAILS.. See de film strip on either sides of de picture?? THIS CAUSES ME ALOT OF CONFUSION WHEN I DO MY MOVIE EDITING AND STUFF BECAUSE I USE THIS VIEW..
Thank u and sorry for my english...
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
You're welcome Pramodm. I'm happy to hear that you got it sorted now. :)
Pramodm,
If it's about a different subject, then it would be best to start a new thread to get the best response with it. :)
