Go Back   Vista Forums > Vista Forums > General Discussion
Vista - BSoD recuuring problems please help
Old 07-05-2009   #21 (permalink)
Vista Ultimate x64; Win 7 x64 and x32
Re: BSoD recuuring problems please help
Interestingly, the debugger can't locate symbols for the pshed.dll file (which is one of the files that processes the hardware error). This could point to an issue with the OS itself. Is this a legitimate installation of Windows that's been activated through Microsoft? If so, I'd run SFC.EXE /SCANNOW from an elevated command prompt to see if it's fixable.
This is another STOP 0x124 error and occurred due to hardware while operating in CoDWaWmp.exe Lot's of issues on the web with cracked copies - is this the case with your copy? If not, then we're back to suspecting either the networking drivers, or the network devices themselves.
To test, disable your wired connection in Device Manager and only use the wireless for a day or two. Then switch around, disabling the wireless and only using the wired connection for a day or two.
Here's the memory dump file:
Code:
Microsoft (R) Windows Debugger Version 6.11.0001.404 AMD64
Loading Dump File [C:\Users\FUBAR-RC1-Desktop\TempDUMP\DATA\01.dmp]
Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows Server 2008/Windows Vista Kernel Version 6002 (Service Pack 2) MP (4 procs) Free x64
Built by: 6002.18005.amd64fre.lh_sp2rtm.090410-1830
Machine Name:
Kernel base = 0xfffff800`02415000 PsLoadedModuleList = 0xfffff800`025d9dd0
Debug session time: Sun Jul  5 10:53:14.904 2009 (GMT-4)
System Uptime: 0 days 0:03:50.646
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck 124, {0, fffffa8005875030, f2000008, 2000e0f}
***    Your debugger is not using the correct symbols                 ***
***    In order for this command to work properly, your symbol path   ***
***    must point to .pdb files that have full type information.      ***
***    Certain .pdb files (such as the public OS symbols) do not      ***
***    contain the required information.  Contact the group that      ***
***    provided you with these symbols if you need this command to    ***
***    work.                                                          ***
***    Type referenced: pshed!_WHEA_ERROR_RECORD_HEADER                ***
***    work.                                                          ***
***    Type referenced: pshed!_WHEA_ERROR_RECORD_SECTION_DESCRIPTOR                ***
***    work.                                                          ***
***    work.                                                          ***
***    work.                                                          ***
Probably caused by : hardware
Followup: MachineOwner
3: kd> !thread;!analyze -v;r;kv;lmtn;lmtsmn;.bugcheck;.logclose;q
GetPointerFromAddress: unable to read from fffff8000263c000
THREAD fffffa800668abb0  Cid 0ff8.07c0  Teb: 000000007ef97000 Win32Thread: 0000000000000000 RUNNING on processor 3
Not impersonating
GetUlongFromAddress: unable to read from fffff800025bbc00
Owning Process            fffffa8006f4f040       Image:         CoDWaWmp.exe
Attached Process          N/A            Image:         N/A
fffff78000000000: Unable to get shared data
Wait Start TickCount      14761
Context Switch Count      885
ReadMemory error: Cannot get nt!KeMaximumIncrement value.
UserTime                  00:00:00.000
KernelTime                00:00:00.000
Win32 Start Address 0x000000006ebf9fca
Stack Init fffffa6007b5bdb0 Current fffffa6007b5baa0
Base fffffa6007b5c000 Limit fffffa6007b56000 Call 0
Priority 8 BasePriority 8 PriorityDecrement 0 IoPriority 2 PagePriority 5
Child-SP          RetAddr           : Args to Child                                                           : Call Site
fffffa60`019df958 fffff800`029348ba : 00000000`00000124 00000000`00000000 fffffa80`05875030 00000000`f2000008 : nt!KeBugCheckEx
fffffa60`019df960 fffff800`02536033 : 00000000`00000001 00000000`00000001 00000000`00000000 00000000`00000001 : hal!HalBugCheckSystem+0x12e
fffffa60`019df9d0 fffff800`029341bc : fffffa60`00000c3e fffffa60`019dfbb0 fffffa60`019dfc30 00000000`00000000 : nt!WheaReportHwError+0x243
fffffa60`019dfa30 fffff800`0246e6b1 : 00000000`177cfafc fffffa60`019dfc30 00000000`00000003 00000000`00000000 : hal!HalpMcaExceptionHandler+0x114
fffffa60`019dfa70 fffff800`0246e4f5 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxMcheckAbort+0x71
fffffa60`019dfbb0 00000000`6ea35313 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiMcheckAbort+0xf5 (TrapFrame @ fffffa60`019dfbb0)
00000000`177cf88c 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x6ea35313
WHEA_UNCORRECTABLE_ERROR (124)
A fatal hardware error has occurred. Parameter 1 identifies the type of error
source that reported the error. Parameter 2 holds the address of the
WHEA_ERROR_RECORD structure that describes the error conditon.
Arguments:
Arg1: 0000000000000000, Machine Check Exception
Arg2: fffffa8005875030, Address of the WHEA_ERROR_RECORD structure.
Arg3: 00000000f2000008, High order 32-bits of the MCi_STATUS value.
Arg4: 0000000002000e0f, Low order 32-bits of the MCi_STATUS value.
Debugging Details:
***    work.                                                          ***
***    work.                                                          ***
***    work.                                                          ***
***    work.                                                          ***
***    work.                                                          ***
BUGCHECK_STR:  0x124_GenuineIntel
DEFAULT_BUCKET_ID:  VERIFIER_ENABLED_VISTA_MINIDUMP
PROCESS_NAME:  CoDWaWmp.exe
CURRENT_IRQL:  f
STACK_TEXT:
STACK_COMMAND:  kb
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: hardware
IMAGE_NAME:  hardware
DEBUG_FLR_IMAGE_TIMESTAMP:  0
FAILURE_BUCKET_ID:  X64_0x124_GenuineIntel_VRF__UNKNOWN
rax=0000000002000e0f rbx=fffffa8005875030 rcx=0000000000000124
rdx=0000000000000000 rsi=fffffa8005875150 rdi=0000000000000002
rip=fffff8000246f450 rsp=fffffa60019df958 rbp=fffffa8005875000
 r8=fffffa8005875030  r9=00000000f2000008 r10=dbf3c493f1165eb6
r11=fffff8000292d000 r12=fffffa80027fe690 r13=fffffa80057ffbc0
r14=fffffa80027fc9c8 r15=0000000075053380
iopl=0         nv up ei pl nz na pe nc
cs=0010  ss=0000  ds=002b  es=002b  fs=0053  gs=002b             efl=00000202
nt!KeBugCheckEx:
fffff800`0246f450 48894c2408      mov     qword ptr [rsp+8],rcx ss:fffffa60`019df960=0000000000000124
start             end                 module name
fffff800`02415000 fffff800`0292d000   nt       ntkrnlmp.exe Sat Apr 11 00:58:39 2009 (49E0237F)
fffff800`0292d000 fffff800`02973000   hal      hal.dll      Sat Apr 11 03:04:56 2009 (49E04118)
fffff960`00030000 fffff960`002e1000   win32k   win32k.sys   Tue Apr 21 08:03:41 2009 (49EDB61D)
fffff960`004c0000 fffff960`004ca000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff960`00620000 fffff960`00631000   cdd      cdd.dll      Sat Apr 11 03:03:49 2009 (49E040D5)
fffffa60`00605000 fffffa60`0060f000   kdcom    kdcom.dll    Sat Apr 11 03:07:57 2009 (49E041CD)
fffffa60`0060f000 fffffa60`0064a000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Sat Apr 11 03:05:41 2009 (49E04145)
fffffa60`0064a000 fffffa60`0065e000   PSHED    PSHED.dll    Sat Apr 11 03:08:17 2009 (49E041E1)
fffffa60`0065e000 fffffa60`006bb000   CLFS     CLFS.SYS     Sat Apr 11 00:54:21 2009 (49E0227D)
fffffa60`006bb000 fffffa60`0076d000   CI       CI.dll       Sat Apr 11 03:08:09 2009 (49E041D9)
fffffa60`0076d000 fffffa60`007d3000   volmgrx  volmgrx.sys  Sat Apr 11 01:35:14 2009 (49E02C12)
fffffa60`007d3000 fffffa60`007f7000   ataport  ataport.SYS  Sat Apr 11 01:34:25 2009 (49E02BE1)
fffffa60`0080d000 fffffa60`008e7000   Wdf01000 Wdf01000.sys Sat Jan 19 01:33:27 2008 (479199B7)
fffffa60`008e7000 fffffa60`008f5000   WDFLDR   WDFLDR.SYS   Sat Jan 19 01:32:33 2008 (47919981)
fffffa60`008f5000 fffffa60`0094b000   acpi     acpi.sys     Sat Apr 11 01:03:26 2009 (49E0249E)
fffffa60`0094b000 fffffa60`00954000   WMILIB   WMILIB.SYS   Sat Jan 19 01:33:45 2008 (479199C9)
fffffa60`00954000 fffffa60`0095e000   msisadrv msisadrv.sys Sat Jan 19 01:02:50 2008 (4791928A)
fffffa60`0095e000 fffffa60`0098e000   pci      pci.sys      Sat Apr 11 01:03:33 2009 (49E024A5)
fffffa60`0098e000 fffffa60`009a3000   partmgr  partmgr.sys  Sat Apr 11 01:34:51 2009 (49E02BFB)
fffffa60`009a3000 fffffa60`009b7000   volmgr   volmgr.sys   Sat Apr 11 01:34:49 2009 (49E02BF9)
fffffa60`009b7000 fffffa60`009be000   pciide   pciide.sys   Sat Apr 11 01:34:28 2009 (49E02BE4)
fffffa60`009be000 fffffa60`009ce000   PCIIDEX  PCIIDEX.SYS  Sat Apr 11 01:34:22 2009 (49E02BDE)
fffffa60`009ce000 fffffa60`009e1000   mountmgr mountmgr.sys Sat Jan 19 01:28:01 2008 (47919871)
fffffa60`009e1000 fffffa60`009e9000   atapi    atapi.sys    Sat Apr 11 01:34:19 2009 (49E02BDB)
fffffa60`009e9000 fffffa60`009f9000   nvstor   nvstor.sys   Wed Jun 06 16:34:00 2007 (46671A38)
fffffa60`00a06000 fffffa60`00a63000   storport storport.sys Sat Apr 11 01:34:45 2009 (49E02BF5)
fffffa60`00a63000 fffffa60`00a8f000   nvstor64 nvstor64.sys Wed Nov 12 19:57:58 2008 (491B7B96)
fffffa60`00a8f000 fffffa60`00ad6000   fltmgr   fltmgr.sys   Sat Apr 11 00:54:38 2009 (49E0228E)
fffffa60`00ad6000 fffffa60`00aea000   fileinfo fileinfo.sys Sat Jan 19 01:05:23 2008 (47919323)
fffffa60`00aea000 fffffa60`00b70000   ksecdd   ksecdd.sys   Sat Apr 11 01:21:49 2009 (49E028ED)
fffffa60`00b70000 fffffa60`00bc0000   msrpc    msrpc.sys    Sat Apr 11 01:32:13 2009 (49E02B5D)
fffffa60`00bc0000 fffffa60`00bec000   ecache   ecache.sys   Sat Apr 11 01:36:18 2009 (49E02C52)
fffffa60`00c0f000 fffffa60`00dd2000   ndis     ndis.sys     Sat Apr 11 01:43:15 2009 (49E02DF3)
fffffa60`00dd2000 fffffa60`00dfe000   fwpkclnt fwpkclnt.sys Sat Apr 11 01:42:44 2009 (49E02DD4)
fffffa60`00e0c000 fffffa60`00e65000   NETIO    NETIO.SYS    Sat Apr 11 01:43:34 2009 (49E02E06)
fffffa60`00e65000 fffffa60`00fda000   tcpip    tcpip.sys    Sat Apr 11 01:44:47 2009 (49E02E4F)
fffffa60`00fda000 fffffa60`00fee000   disk     disk.sys     Sat Apr 11 01:34:38 2009 (49E02BEE)
fffffa60`01000000 fffffa60`0100e000   vga      vga.sys      Sat Jan 19 01:32:21 2008 (47919975)
fffffa60`0100e000 fffffa60`0118e000   Ntfs     Ntfs.sys     Sat Apr 11 00:55:38 2009 (49E022CA)
fffffa60`0118e000 fffffa60`011d2000   volsnap  volsnap.sys  Sat Apr 11 01:35:33 2009 (49E02C25)
fffffa60`011d2000 fffffa60`011da000   spldr    spldr.sys    Mon Jan 12 16:51:29 2009 (496BBB61)
fffffa60`011da000 fffffa60`011e1000   speedfan speedfan.sys Sun Sep 24 09:26:48 2006 (45168798)
fffffa60`011e1000 fffffa60`011f3000   mup      mup.sys      Sat Apr 11 00:54:47 2009 (49E02297)
fffffa60`01200000 fffffa60`01209000   Null     Null.SYS     Thu Nov 02 05:37:15 2006 (4549BC4B)
fffffa60`0120c000 fffffa60`01238000   CLASSPNP CLASSPNP.SYS Sat Apr 11 01:34:15 2009 (49E02BD7)
fffffa60`01238000 fffffa60`01242000   crcdisk  crcdisk.sys  Sat Jan 19 01:30:12 2008 (479198F4)
fffffa60`01242000 fffffa60`0125e000   cdfs     cdfs.sys     Sat Jan 19 00:53:45 2008 (47919069)
fffffa60`01264000 fffffa60`01270000   tunnel   tunnel.sys   Sat Jan 19 01:36:44 2008 (47919A7C)
fffffa60`01270000 fffffa60`01279000   tunmp    tunmp.sys    Sat Jan 19 01:36:30 2008 (47919A6E)
fffffa60`01279000 fffffa60`0128c000   intelppm intelppm.sys Sat Jan 19 00:52:45 2008 (4791902D)
fffffa60`0128c000 fffffa60`0129c000   watchdog watchdog.sys Sat Apr 11 01:09:16 2009 (49E025FC)
fffffa60`0129c000 fffffa60`012a9000   fdc      fdc.sys      Sat Jan 19 01:28:45 2008 (4791989D)
fffffa60`012a9000 fffffa60`012c5000   parport  parport.sys  Sat Jan 19 01:28:36 2008 (47919894)
fffffa60`012c5000 fffffa60`012db000   i8042prt i8042prt.sys Sat Jan 19 01:28:08 2008 (47919878)
fffffa60`012db000 fffffa60`012e9000   kbdclass kbdclass.sys Sat Jan 19 01:28:05 2008 (47919875)
fffffa60`012e9000 fffffa60`01306000   serial   serial.sys   Sat Jan 19 01:28:41 2008 (47919899)
fffffa60`01306000 fffffa60`01312000   serenum  serenum.sys  Sat Jan 19 01:28:36 2008 (47919894)
fffffa60`01312000 fffffa60`0131d000   usbohci  usbohci.sys  Sat Apr 11 01:39:36 2009 (49E02D18)
fffffa60`0131d000 fffffa60`01363000   USBPORT  USBPORT.SYS  Sat Apr 11 01:39:39 2009 (49E02D1B)
fffffa60`01363000 fffffa60`01374000   usbehci  usbehci.sys  Sat Apr 11 01:39:36 2009 (49E02D18)
fffffa60`01374000 fffffa60`01390000   cdrom    cdrom.sys    Sat Apr 11 01:34:39 2009 (49E02BEF)
fffffa60`01390000 fffffa60`013a1b00   ohci1394 ohci1394.sys Sat Apr 11 01:39:49 2009 (49E02D25)
fffffa60`013a2000 fffffa60`013b1f00   1394BUS  1394BUS.SYS  Sat Jan 19 01:34:04 2008 (479199DC)
fffffa60`013b2000 fffffa60`013fa000   usbhub   usbhub.sys   Sat Apr 11 01:39:52 2009 (49E02D28)
fffffa60`02e03000 fffffa60`03919680   nvlddmkm nvlddmkm.sys Wed Jun 10 10:31:48 2009 (4A2FC3D4)
fffffa60`0391a000 fffffa60`0391b180   nvBridge nvBridge.kmd Wed Jun 10 09:24:21 2009 (4A2FB405)
fffffa60`0391c000 fffffa60`039fd000   dxgkrnl  dxgkrnl.sys  Sat Apr 11 01:10:13 2009 (49E02635)
fffffa60`03c06000 fffffa60`03cf3000   HDAudBus HDAudBus.sys Sat Apr 11 01:39:38 2009 (49E02D1A)
fffffa60`03cf3000 fffffa60`03d24000   ndiswan  ndiswan.sys  Sat Apr 11 01:43:39 2009 (49E02E0B)
fffffa60`03d24000 fffffa60`03d42000   raspptp  raspptp.sys  Sat Apr 11 01:43:38 2009 (49E02E0A)
fffffa60`03d42000 fffffa60`03d5a000   rassstp  rassstp.sys  Sat Apr 11 01:43:46 2009 (49E02E12)
fffffa60`03d5a000 fffffa60`03d6d000   termdd   termdd.sys   Sat Apr 11 01:48:13 2009 (49E02F1D)
fffffa60`03d6d000 fffffa60`03d6e480   swenum   swenum.sys   Thu Nov 02 05:37:33 2006 (4549BC5D)
fffffa60`03d6f000 fffffa60`03da3000   ks       ks.sys       Sat Apr 11 01:33:51 2009 (49E02BBF)
fffffa60`03da3000 fffffa60`03dae000   mssmbios mssmbios.sys Sat Jan 19 01:02:54 2008 (4791928E)
fffffa60`03dae000 fffffa60`03dbe000   umbus    umbus.sys    Sat Jan 19 01:34:16 2008 (479199E8)
fffffa60`03dbe000 fffffa60`03dc9000   flpydisk flpydisk.sys Sat Jan 19 01:28:45 2008 (4791989D)
fffffa60`03dc9000 fffffa60`03ddd000   NDProxy  NDProxy.SYS  Sat Jan 19 01:37:26 2008 (47919AA6)
fffffa60`03ddd000 fffffa60`03e00000   drmk     drmk.sys     Sat Jan 19 02:20:04 2008 (4791A4A4)
fffffa60`03e01000 fffffa60`03f6d180   nvmfdx64 nvmfdx64.sys Fri Aug 01 14:38:28 2008 (48935824)
fffffa60`03f6e000 fffffa60`03fa7000   msiscsi  msiscsi.sys  Sat Apr 11 01:36:09 2009 (49E02C49)
fffffa60`03fa7000 fffffa60`03fb4000   TDI      TDI.SYS      Sat Apr 11 01:44:14 2009 (49E02E2E)
fffffa60`03fb4000 fffffa60`03fd7000   rasl2tp  rasl2tp.sys  Sat Apr 11 01:43:37 2009 (49E02E09)
fffffa60`03fd7000 fffffa60`03fe3000   ndistapi ndistapi.sys Sat Jan 19 01:37:22 2008 (47919AA2)
fffffa60`03fe3000 fffffa60`03ff3000   raspppoe raspppoe.sys Sat Apr 11 01:43:33 2009 (49E02E05)
fffffa60`03ff3000 fffffa60`03fff000   mouclass mouclass.sys Sat Jan 19 01:28:05 2008 (47919875)
fffffa60`04609000 fffffa60`0462e000   VIDEOPRT VIDEOPRT.SYS Sat Jan 19 01:32:25 2008 (47919979)
fffffa60`0462e000 fffffa60`04637000   hidusb   hidusb.sys   Sat Apr 11 01:39:32 2009 (49E02D14)
fffffa60`04637000 fffffa60`04649000   HIDCLASS HIDCLASS.SYS Sat Apr 11 01:39:32 2009 (49E02D14)
fffffa60`04649000 fffffa60`04650b80   HIDPARSE HIDPARSE.SYS Sat Jan 19 01:33:51 2008 (479199CF)
fffffa60`04651000 fffffa60`04652e00   USBD     USBD.SYS     Sat Jan 19 01:33:53 2008 (479199D1)
fffffa60`04653000 fffffa60`0465e000   mouhid   mouhid.sys   Sat Jan 19 01:28:10 2008 (4791987A)
fffffa60`0465e000 fffffa60`04667000   RDPCDD   RDPCDD.sys   Sat Jan 19 01:42:04 2008 (47919BBC)
fffffa60`04667000 fffffa60`04670000   rdpencdd rdpencdd.sys Sat Jan 19 01:42:03 2008 (47919BBB)
fffffa60`04670000 fffffa60`0467b000   Msfs     Msfs.SYS     Sat Jan 19 00:53:55 2008 (47919073)
fffffa60`0467b000 fffffa60`0468c000   Npfs     Npfs.SYS     Sat Apr 11 00:54:22 2009 (49E0227E)
fffffa60`0468c000 fffffa60`04695000   rasacd   rasacd.sys   Sat Jan 19 01:37:30 2008 (47919AAA)
fffffa60`04695000 fffffa60`046b2000   tdx      tdx.sys      Sat Apr 11 01:43:00 2009 (49E02DE4)
fffffa60`046b2000 fffffa60`046cd000   smb      smb.sys      Sat Apr 11 01:42:19 2009 (49E02DBB)
fffffa60`046cd000 fffffa60`046de000   aswTdi   aswTdi.SYS   Thu Feb 05 16:06:22 2009 (498B54CE)
fffffa60`046de000 fffffa60`04749000   afd      afd.sys      Sat Apr 11 01:44:21 2009 (49E02E35)
fffffa60`04749000 fffffa60`04752000   aswRdr   aswRdr.SYS   Thu Feb 05 16:06:11 2009 (498B54C3)
fffffa60`04752000 fffffa60`04796000   netbt    netbt.sys    Sat Apr 11 01:42:31 2009 (49E02DC7)
fffffa60`04796000 fffffa60`047b4000   pacer    pacer.sys    Sat Apr 11 01:42:56 2009 (49E02DE0)
fffffa60`047b4000 fffffa60`047bf000   rtlprot  rtlprot.sys  Fri Apr 20 05:16:48 2007 (46288500)
fffffa60`047bf000 fffffa60`047ce000   netbios  netbios.sys  Sat Jan 19 01:36:35 2008 (47919A73)
fffffa60`047ce000 fffffa60`047e9000   wanarp   wanarp.sys   Sat Apr 11 01:43:38 2009 (49E02E0A)
fffffa60`04800000 fffffa60`0480a000   Fs_Rec   Fs_Rec.SYS   Sat Jan 19 00:53:41 2008 (47919065)
fffffa60`0480c000 fffffa60`049bce80   RTKVHD64 RTKVHD64.sys Tue Jun 16 06:12:51 2009 (4A377023)
fffffa60`049bd000 fffffa60`049f8000   portcls  portcls.sys  Sat Apr 11 01:39:36 2009 (49E02D18)
fffffa60`049f8000 fffffa60`049fd180   ksthunk  ksthunk.sys  Sat Jan 19 01:28:14 2008 (4791987E)
fffffa60`04a03000 fffffa60`04a50000   rdbss    rdbss.sys    Sat Apr 11 00:55:21 2009 (49E022B9)
fffffa60`04a50000 fffffa60`04a5c000   nsiproxy nsiproxy.sys Sat Jan 19 01:36:45 2008 (47919A7D)
fffffa60`04a5c000 fffffa60`04a79000   dfsc     dfsc.sys     Sat Apr 11 00:54:44 2009 (49E02294)
fffffa60`04a79000 fffffa60`04a95000   aswSP    aswSP.SYS    Thu Feb 05 16:07:35 2009 (498B5517)
fffffa60`04a95000 fffffa60`04af3000   wg111v3  wg111v3.sys  Fri Dec 28 01:59:29 2007 (47749ED1)
fffffa60`04af3000 fffffa60`04b01000   crashdmp crashdmp.sys Sat Apr 11 01:34:31 2009 (49E02BE7)
fffffa60`04b01000 fffffa60`04b0d000   dump_dumpata dump_dumpata.sys Sat Apr 11 01:34:22 2009 (49E02BDE)
fffffa60`04b0d000 fffffa60`04b15000   dump_atapi dump_atapi.sys Sat Apr 11 01:34:19 2009 (49E02BDB)
fffffa60`04b15000 fffffa60`04b21000   Dxapi    Dxapi.sys    Sat Jan 19 01:08:00 2008 (479193C0)
fffffa60`04b21000 fffffa60`04b34000   monitor  monitor.sys  Sat Jan 19 01:32:34 2008 (47919982)
fffffa60`04b34000 fffffa60`04b56000   luafv    luafv.sys    Sat Jan 19 00:59:06 2008 (479191AA)
fffffa60`04b56000 fffffa60`04b70000   aswMonFlt aswMonFlt.sys Thu Feb 05 16:07:05 2009 (498B54F9)
fffffa60`04b70000 fffffa60`04b79000   aswFsBlk aswFsBlk.sys Thu Feb 05 16:07:15 2009 (498B5503)
fffffa60`04b79000 fffffa60`04b97000   bowser   bowser.sys   Sat Jan 19 00:54:51 2008 (479190AB)
fffffa60`04b97000 fffffa60`04bbe000   mrxdav   mrxdav.sys   Sat Apr 11 00:55:42 2009 (49E022CE)
fffffa60`04bbe000 fffffa60`04be7000   mrxsmb   mrxsmb.sys   Sat Apr 11 00:55:33 2009 (49E022C5)
fffffa60`0840d000 fffffa60`084a7000   spsys    spsys.sys    Tue Mar 10 13:16:43 2009 (49B6A07B)
fffffa60`084a7000 fffffa60`084bb000   lltdio   lltdio.sys   Sat Jan 19 01:35:48 2008 (47919A44)
fffffa60`084bb000 fffffa60`084ef000   nwifi    nwifi.sys    Sat Apr 11 01:40:19 2009 (49E02D43)
fffffa60`084ef000 fffffa60`084fa000   ndisuio  ndisuio.sys  Sat Jan 19 01:36:29 2008 (47919A6D)
fffffa60`084fa000 fffffa60`08512000   rspndr   rspndr.sys   Sat Jan 19 01:35:48 2008 (47919A44)
fffffa60`08512000 fffffa60`0851d000   asyncmac asyncmac.sys Sat Jan 19 01:37:27 2008 (47919AA7)
fffffa60`0851d000 fffffa60`085bc000   HTTP     HTTP.sys     Sat Apr 11 01:42:20 2009 (49E02DBC)
fffffa60`085bc000 fffffa60`085e5000   srvnet   srvnet.sys   Sat Apr 11 00:57:28 2009 (49E02338)
fffffa60`085e5000 fffffa60`085ff000   mpsdrv   mpsdrv.sys   Sat Jan 19 01:35:28 2008 (47919A30)
fffffa60`08c04000 fffffa60`08c4d000   mrxsmb10 mrxsmb10.sys Sat Apr 11 00:55:23 2009 (49E022BB)
fffffa60`08c4d000 fffffa60`08c6c000   mrxsmb20 mrxsmb20.sys Sat Apr 11 00:55:26 2009 (49E022BE)
fffffa60`08c6c000 fffffa60`08c9e000   srv2     srv2.sys     Sat Apr 11 00:57:35 2009 (49E0233F)
fffffa60`08c9e000 fffffa60`08d2f000   srv      srv.sys      Sat Apr 11 00:57:52 2009 (49E02350)
fffffa60`08d2f000 fffffa60`08de5000   peauth   peauth.sys   Mon Oct 23 07:57:00 2006 (453CAE0C)
fffffa60`08de5000 fffffa60`08df0000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffffa60`08df0000 fffffa60`08e00000   tcpipreg tcpipreg.sys Sat Apr 11 01:43:04 2009 (49E02DE8)
Unloaded modules:
fffffa60`01242000 fffffa60`01250000   crashdmp.sys
    Timestamp: unavailable (00000000)
    Checksum:  00000000
fffffa60`01250000 fffffa60`0125c000   dump_ataport
    Checksum:  00000000
fffffa60`0125c000 fffffa60`01264000   dump_atapi.s
    Checksum:  00000000
Unloaded modules:
    Checksum:  00000000
    Checksum:  00000000
    Checksum:  00000000
Bugcheck code 00000124
Arguments 00000000`00000000 fffffa80`05875030 00000000`f2000008 00000000`02000e0f
Old 07-05-2009   #22 (permalink)
Vista Home Premium x64
"Windows resource protection did not find any integrity violations" according to the scan. Also, I'm pretty sure my windows edition is legit. When I checked my wireless adapters, I noticed that I had 2, the Netgear wireless adapter and the Nvidia nForce Ethernet, so I disabled the nForce one.
Old 07-05-2009   #23 (permalink)
Are any of the games "cracked"?
Let it run for a while (a day or two) with the nForce disabled. If you don't get any BSOD's, then that was likely the problem.
If you still get BSOD's, disable the wireless and use the nForce (wired) to connect to the internet for a couple of days.
If don't get BSOD's, then it's likely that we've solved it. If you do, we'll have to spend some more time looking.
Old 07-06-2009   #24 (permalink)
I think we've solved it. I've been on COD:WAW, which would crash after about 10-20 mins, for about 2hrs without a single BSoD. I'm not saying thats conclusive but so far so good.
Old 07-06-2009   #25 (permalink)
I'll keep my fingers crossed and will knock on wood - just to be sure!
Old 07-07-2009   #26 (permalink)
Update: For all of yesterday, I didnt get a single BSoD. However, I've got three today. I've uploaded those three minidumps.
Old 07-07-2009   #27 (permalink)
What has changed, did you disable the wireless adapter? Did you disable the wired adapter?
The nVidia Storage drivers, your Realtek NIC, and your wireless drivers are still listed as being from 2007/2006.
Old 07-07-2009   #28 (permalink)
It was working perfectly with the wired adapter (NVIDIA nForce 10/100/1000 Mbps Ethernet)disabled yesterday then, with it still disabled, I got BSoDs today. So I uninstalled it, which still didnt help. So I reinstalled it again then I disabled it, but still got crashes, then I enabled then disabled it (again) and it has now been working for about 2hrs without a BSoD (???). I think it must be something to do with this driver. I find it odd that those drivers are listed as being from 2006/2007 because I updated them last week.
Update: Just got a BSoD.
Old 07-07-2009   #29 (permalink)
I'll ask again. Is any of this due to "cracked" software? If so the standard troubleshooting tools won't work - and we'll spin our wheels forever.
This is (IMO) either:
- a compatibility issue with your hardware
- a hardware failure
- an incompatible software issue
Can you physically remove the wireless or the wired card? Can you disable them in the BIOS if they're not removable?
Old 07-08-2009   #30 (permalink)
All my software has been bought legitimally (mostly from shops). I can physically remove the wireless adapter but this will mean that I cannot access the internet because I don't have I phone line near my computer, hence why I have wireless. I can't remove the wired card because I think its built into the mobo
BSoD Problems Vista hardware & devices
BSOD problems, help needed. General Discussion
BSOD problems General Discussion
BSOD problems in x64 vista General Discussion
BSOD and other problems...... Vista installation & setup
