Go Back   Vista Forums > Vista Forums > General Discussion
Vista - BSoD recuuring problems please help
Old 07-08-2009   #31 (permalink)
Vista Ultimate x64; Win 7 x64 and x32
Re: BSoD recuuring problems please help
If the wired card is built into the mobo, you should be able to disable it in the BIOS.
If you can't live without the wireless, try another wireless card (if you buy it, make sure you can return it if it doesn't fix the problem).
Try running the Vista Upgrade Advisor to see if it finds any issues: http://www.microsoft.com/downloads/d...displaylang=en
BSoD Problems Vista hardware & devices
BSOD problems, help needed. General Discussion
BSOD problems General Discussion
BSOD problems in x64 vista General Discussion
BSOD and other problems...... Vista installation & setup
