Please Help, Major slowdown Problem
braders95
Hi users,
I have had a major problem for a while now with my fujitsu siemens laptop, I can use it for about 1 week or so and the laptop will run very slow and will not allow me to access any applications, and my computer acctually crashes now, And yes I have had that annoying blue screen.
I have no choice but to wipe the hard drive fully, then re-install windows vista 32bit via the Fujitsu Siemens Recovery Console, I will say I never shut my computer down, I only ever put it on hibernate because I hate waiting for it to boot up, And I do know that the hibernate feature can affect the hard drive, but I can not see why I have this problem,
Please Help,
Thanks
Jamie
    Fujitsu Siemens Notebook
    Intel Core 2 Duo
    3GB
    ALBA 15" HDMI TV
    Trust Wireless Keyboard
    Trust Wireless Mouse
    Don't Know (But Slow)
    <b> Dream Computer
    1.5TB Hard Drives (X2) £100
    Water Cooled System
Hello Jamie,
Welcome to the Forum. I'm sorry to hear you have got problem with your lappy.
It's not good idea to run the computer without shuting it down once in a while. Perheps you are right that the operating system will boot a little faster from the hibernate mode, but not always. I could say my machine will boot a lot faster when I shut it down completely than I put it in the hibernate.
You could improve the booting time if you follow this tutorial. I think you might be interested in this tutorial how to speed up performance Vista as well.
Hope it helps. Cheers...
    Gateway P7805u FX
    Intel PM45
    8GB 1066MHz DDR3
    LG 17" WUXGA TFT
    1920x 1200
    WD 2x500GB
    notebook
    BT/BD
Hello Jamie,
There is a good reason for me putting it in hibernate mode though, because i have to activate my laptop's WI-FI everytime i turn it on and it struggles to get hold of the connection so at least when i put it on hibernate i can continue with tthe work I was doing.
but ok I will try that, thanks
    Intel Core 2 Duo
    3GB
    ALBA 15" HDMI TV
    <b> Dream Computer
    Water Cooled System
my wife has a laptop we never turn it off its fine been doing it for 2 years..
after you reformat your laptop what programs do you install? do you have alot running at startup? something may be bogging it down
navigate to c/windows/minidump in there there will be some .dmp files (information on yuor bluescreen) zip em up using winzip or summat and attach it to your next post
    XFX 780i
    4GB OCZ PC2-8500C5 DDR2
    Gainward GTX260/216 SLI
    Creative X-FI Xtreme Gamer
    Dell UltraSharp 2209WA 22"
    OCZ Modstream 700w
    Titan Fenir
    Razer Reclusa
    Logitech G5 Gamer
    8mb
Right I have attached them (Password: vista)
Also I do have to admit I do have alot of software installed on my computer but i do remove most of it from Computer Manegement anyways, but the problem is not the software it just takes to long to load because if I have loads of software at the beginning of the week it will be fine but then at the end of the week even if I defrag and uninstall stuff I have the same problem
Thanks
  • Minidump.zip
    Intel Core 2 Duo
    3GB
    ALBA 15" HDMI TV
    <b> Dream Computer
    Water Cooled System
nice one ill have alook at them later , somebody else may happen along and have a go at them too :)
    XFX 780i
    OCZ Modstream 700w
    Titan Fenir
    Razer Reclusa
    Logitech G5 Gamer
    8mb
