| Premium 32bit | Problem with Mouse Pointer Hi there I recently had a power failure whilst working on my PC - I restarted it - but started getting problems - I have put both C and D drives through the Check Disk Utility. To all intends iand purposes the Pc appears to be workin, except: 1. The Mouse pointer has the `working in the background` - i.e. the revolving circle which goes on for 5 secs then off for 1 sec and back to 5 secs etc. I have tried changing the pointer but to no avail. 2. I can not delete anything in the C/ directorory Program Files Any help/suggestions would be much appreciated |
| Vista | Re: Problem with Mouse Pointer Have you tried starting in safe mode? If you do, are you getting any of the same issues? Just as a precaution, I'd recommend backing up your files (that is, if you haven't already), in the case that something may happen or that you need to reinstall anything. |
| Premium 32bit | Problem with Mouse Pointer and possible C drive Hi there The power to my PC was accidently switched off and on - delay about 30 seconds, then I have had all sorts of problems. ![]() 1. I got a message that certain files were corrupt - have have since used Check Disk Utilty on both C and D drives and it appears to have cured it. ![]() 2. On trying to use the Live Mail it kept asking for my password - I appear to have cured that ![]() 3. I now have the Mouse pointer with the `working in the background` icon - that is the revolving circle - which goes on and off every second for 5 seconds - I have tried to change it in the Mouse settings in the Control Panel - that is go back to default but it just stays the same. 4. I suspect that there is something amiss in the `C` drive as I have tried to delete a file in the Program Files - it will not delete. ![]() The PC is, to all intents and purposes functioning reasonable well. I would appreciate any Help/Suggestions many thanks Jim Merriless |
| Premium 32bit | Re: Problem with Mouse Pointer Hello there RONS WIN TEAM Many thanks for your response and sorry for the delay in acknowledging same but I have been away for two (2) days. In Safe Mode the Mouse Pointer acts as normal, that is it does not have working in the background - when I re-boot the Mouse Pointer is as before. Yes I BackedUp my system and on reviewing the BackUp Log, It says `UNABLE TO BACKUP 29 FILES` The system (PC) appears to be operating okay - so it must be something simple that is causing the problem Would appreciate any futher suggestions/help Again amny thanks Jim Merrilees |
| Vista Home Premium 32bit | Re: Problem with Mouse Pointer Jim Merrilees: You haven't mentioned whether you have tried the System Restore function. Ardneh |
| | #6 (permalink) |
| Premium 32bit | Re: Problem with Mouse Pointer Hi there Ardneh Many thanks for your reply - much appreciated - Yes -I have tried System Restore (not as good as XP) but seem that I can not get backto a date that I want for example it will only let me go back tgo 14 July 2009 - I want to the 10th and before. I know that I must be going wrong some where - of course that is to be expected as I am a Mechanical Engineer well passed his sell date ( three score years + 10 and another wee bit. I am not over the moon with Vista - it was not my choice - as my previous PC Crashed/Wiped out and my new PC had VISTA installed - so I am waiting on WINDOWS 7 to go on the market - it can not be any worse than VISTA. Sorry to bore you but I cut my teeth on PC`s with AMIGA`s - enough said Once again many thanks for your help Jim M ( must change my user name) Last edited by Jim Merrilees; 07-26-2009 at 01:18 PM.. |
| | #7 (permalink) |
| Vista home premium 32bit | Re: Problem with Mouse Pointer There may be some corrupted system files. Try sfc /scannow in cmd (as admin). It may fix the corrupted files. |
| | #8 (permalink) |
| Vista Home Premium 32bit | Re: Problem with Mouse Pointer Jim: Sadly,your experience with System Restore is not unusual. Just to touch on the obvious, I assume you've backed up your personal files in case things deteriorate. You might try troubleshooting with a Clean Boot as described here. How to troubleshoot a problem by performing a clean boot in Windows Vista Best Wishes. Ardneh |
| | #9 (permalink) |
| Premium 32bit | Re: Problem with Mouse Pointer Hi there Ardneh Many thanks for your suggestion to us use a CLEAN BOOT - but no joy - as I said the problem is more annoying than anything with the two arrow pointers oscilating between each other. It is not stopping me from operating my PC - so I will leave it for the present. Many thanks for all your help and assistance Jim M |
| | #10 (permalink) |
| Premium 32bit | Re: Problem with Mouse Pointer |
| Mouse DPI and pointer speed at the Mouse Properties. | Vista General | |||
| Mouse pointer | Vista General | |||
| Mouse pointer shadow problem | Vista General | |||
| mouse and pointer | Vista hardware & devices | |||
| Vista mouse-to-pointer problem | Vista performance & maintenance | |||
