Reformatting Problem
  1. #1
    Newbie
    Vista Home Premium 32bit
    Local Time: 02:13 PM
    Hello,
    I have a problem installing a brand new vista 32bit onto my gateway comp. I have formated my partitions into one. Here's what happens, I load my gateway operating disk into my cd drive then I boot from the disk. It loads up and then I click on install vista icon. I then reformat the partition then I delete the partition then I create a new partition with max memory on it. I then hit next. After I hit next the installation begins. About 60% into the installation i get this message:
    Windows cannot install required files. Network problems maybe preventing Windows from acessing the file. Make sure the compter is connected to the network and restart installation. Error code 0x80070005.
    Plz help! thanks!
  2. #2
    Junior Member
    Rome
    Vista Home Premium x86 (32 bit) and Windows 7 RC1 x86 (32 bits)
    Local Time: 11:13 PM
    italy
    Re: Reformatting Problem
    Try without clicking "Get Latest Updates"
Reformatting Problem problems?
Problem reformatting my Laptop nash160 Vista installation & setup 2 16 Nov 2009
reformatting? juanputik General Discussion 1 20 Jul 2009
Problem after reformatting! Kate210 Vista installation & setup 0 02 Feb 2009
need help in reformatting.. Arakai General Discussion 5 17 Apr 2008
Reformatting with XP =?Utf-8?B?RWxhbmE=?= Vista installation & setup 11 12 Aug 2006
