When I turn on the system is starts to boot up and then the screen goes black for anywhere between 1-2 minutes and then the desktop appears. I don't have many programs starting up when the system starts. I always check the Config.exe file.
Could you list your system specs?
Boot up using safe mode to see if this changes the speed of the startup. This will help us to diagnose the problem.
Is your computer new?
Are you referring to Windows Vista 64 bit operating system ?
Can you post a screenshot of msconfig, you can use the vista snipping tool in accessories. As for the system specs, can you use belarc advisor or type dxdiag in the start menu and "save all information".
Safe mode applies to most microsoft products.
Look here : Safe Mode
Also look at this tutorial :Speed Up the Performance of Vista
What u can do is a start up test.
to d that turn on ur PC and at the first screen that comes up fit F2....
then u just select the start up test or test hard drive.
let it do its works and see results.
Hope this helps.
Here are the attachments
| Similar Threads | ||||
| There was a problem starting winfnz32.rom | hemajith | System Security | 0 | 11 Mar 2010 |
| I have problem starting up Vista - problem with driver | Tomassuver | Drivers | 1 | 15 May 2009 |
| Powering up - Starting - major problem | Johnho50 | Vista General | 2 | 26 Dec 2007 |
| Problem starting speech recognition | Dave | Vista General | 0 | 02 Mar 2007 |
| problem when starting | darthkatzs | Vista General | 2 | 03 Jul 2006 |
