Problem with harddisk
newtonx
Hi....
I have a strange problem with my harddisk. There'e a light idicator on my computer shows that if the harddisk is running or not. After restarting my computer, this ididicator shows that the harddisk is running. This light lasts for many hours even I stopped all the programs running and Internet is disconnected. THe only way to stop this idicator is running a virus scan on the harddisk. After that scan, the idicator's light stops showing that nothing is using the harddisk. The virus scan shows that my computer is clean. Some days this problem doesn't appear but most days I have to do scan. I forced to do this scan because neglecting this may lead to harddisk failure as it happend before.
Any help?
Hello Newtonx,
This is normal for there to almost always be some activity on your hard disk. Vista has many background programs and services that are constantly accessing the hard disk. Some of the most common ones are the Index updating the index during low or idle usage of the computer, System Protection creating a restore point, scheduled Disk Defragmenter scans, etc........
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
Thanks.
This problem happens only when I start my computer. The activity may lasts for hours but after scanning the hard disk for viruses it stops. So, when I start my computer, I will run the scanning to stop this activity. This is the only way to protect my hard disk from failure.
