Go Back   Vista Forums > Vista Forums > General Discussion
Vista - power supply
Old 09-24-2009   #1 (permalink)
windows 7 home premium 64 bit
power supply
hi iam starting to build a new system using the antec 902 case i have got 2 power supplys in mind the antec quattro 1000 or the corsair 1000
i now the antec power supply will fit no problem as fan is on the rear of the unit
it is the corsair as the fan is on the under side of the unit there 2 pic below
picture 2 is the one i would like to do if i go for the corsair due to cable managment but will i run in to heat problem doing it that way
thank you
Old 09-24-2009   #2 (permalink)
Windows Vista Enterprise x64 SP2
Re: power supply
If the heat is not exhausted directly out of the case, I would definitely go with antec.
Old 09-24-2009   #3 (permalink)
Re: power supply
Their literature -> Guaranteed to deliver its full 1000W output at 50șC operating temperature.
That's 122 degrees Fahrenheit.
** EDIT **
Sorry, that was for the Corsair. I should have mentioned that.
Old 09-24-2009   #4 (permalink)
Re: power supply
the fan on the corsair does blowing the air out of the back of the unit but will it cause me any problems if i run it like in picture 2
Old 09-24-2009   #5 (permalink)
Windows 7 x64 build 7100 & Ubuntu 9.04
Re: power supply
What are you debating about here? What are you asking?
~Lordbob
Old 09-24-2009   #6 (permalink)
Re: power supply
As long as it's blowing out the back it should work just fine as in picture 2.
Old 09-25-2009   #7 (permalink)
Re: power supply
Quote  Quote: Originally Posted by lordbob75 View Post
~Lordbob
i was just asking if i could run the corsair power supply like in picture 2 as the fan is on the under side rather than being on the back of the unit
Old 09-25-2009   #8 (permalink)
Vista Home Premium 32bit and Ubuntu 9.10 32bit
Re: power supply
yes you should be able to do that just fine
Old 09-25-2009   #9 (permalink)
Re: power supply
You have a consensus. Go with the Corsair!
Old 09-25-2009   #10 (permalink)
Re: power supply
Quote  Quote: Originally Posted by lemur View Post
i will be ordering as soon as i have my money
Bad power supply?? Vista music pictures video
Need new power supply General Discussion
Power Supply Vista hardware & devices
Power Supply General Discussion
