Vista Problem Help!
Kevbo
I have this mysterious problem in which during the night something happens in vista and I cannot open any programs. Either the vista circle just goes away quickly and nothing happens, or for example in Windows Media Center, it just brings up the error message that it has stopped working. Another specific symptom is that when I go to the arrow to select restart or shutdown, the menu refuses to show up! I hover over the arrow and click on it and nothing happens! A hard restart is sometimes required and then all is better.
I am running Windows Vista 32-bit along with AVG 8.5 Free Edition and IObit Security 360.
If anyone knows what these symptoms mean, feel free to share advice! Thanks everyone!
kevbo
first thing first. we need info about your computer. can you fill in your system specs in the lower left corner of your posts so we know what hardware you have.
One place to investigate is event viewer (type event viewer in search)go to the windows log, application tab and look for errors (red "X" in lef thand column) that relate to anything that could cause your symptoms. tell us the event ID and source code for the most frequent one.
thanks
ken
    Dell Inspiron E 1405
    [email protected]
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
Also look at your scheduled task, is there something running in the background.
Press cntrl alt del and look at the proceses running under task manager.
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Logik
    Technika TKOPTM2
    Creative Inspire 7.1 T7900 Speakers
    Trust Graphics Tablet
Uninstall one antivirus. They are probably conflicting. I'd keep AVG.
    Sony Vaio Z46GDU
    6GB DDR3 1066MHz SDRAM
    13.1" WXGA True Colour Tough
    1600x900
    320GB SATA 7200RPM
    1MB/s
Just to give a quick review of the specs:
HP a1730n (Extremely Modded)
ASUS A8M2N-LA
AMD Athlon 64 X2 6000+ @ 3.1
4GB DDR2 533MHz
WD Caviar Black 640GB 32MB
EVGA 8600GTS 512MB
Corsair 650W PSU
I am kind of thinking it has something to do with a program, and I mention AVG and IObit 360 because I feel as if they may be the culprit. I would like your opinions though :)
Kill Iobit 360, keep AVG and underclock your cpu.
    Sony Vaio Z46GDU
    1600x900
    320GB SATA 7200RPM
    1MB/s
So uninstalling IObit 360 did not help today the computer refused to open up any programs and when I went to load windows media center I got a "windows media center has stopped working error" - I also couldn't open up any other program. I tried ctrl + alt + delete and I got a black screen with this error "Logon process has failed to create the security options dialog - Failure - Security Options." I click OK and back to my desktop I go but I still cannot open programs...
This has stopped occuring on my desktop and is most prevalent on my laptop - The HP G60-125NR. I am running AVG Free 8.5 and have uninstalled IObit 360. I recently reformatted the Hard Drive so I see no reason for this to occur...my guess is it is software?? Can someone help?
Thank you all so much!
Can you post a screenshot of your installed programs. Search for snip in the start menu.
    Sony Vaio Z46GDU
    1600x900
    320GB SATA 7200RPM
    1MB/s
Can you take a look in msconfig and let us know everything that is scheduled to start up?
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Quietkey
    Dell Optical
    10 MBPS
Get rid of the Iobit Advanced System Care junk, Wise cleaning junk and filehippo. Then reboot. They've probably corrupted your registry.
    Sony Vaio Z46GDU
    1600x900
    320GB SATA 7200RPM
    1MB/s
Don't see anything strange in the installed programs
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Quietkey
    Dell Optical
    10 MBPS
Frost - you ready for a restore?
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Quietkey
    Dell Optical
    10 MBPS
    Sony Vaio Z46GDU
    1600x900
    320GB SATA 7200RPM
    1MB/s
