problem with left click
petecotton
ok, my acer 5335 is brand new and has vista basic. when i first connected to the internet i installed all available updates including explorer 8 and vista service pack 2. i also downloaded avg anti virus and sunbelt firewall.
the problem i have is that some links in some sites will not open at all, some need a right click to select 'open' from the menu, and others open as they should with just a single left click.
examples,
on my hotmail page, mails will open with a single left click, but the reply or new mail controls will not respond to right or left.
on autotrader.co.uk i can left click to view details of cars from the listings, but if i want to view the extra pictures i need to right click and select open.
google search works fine and most forum sites as i've been looking for a fix have been ok too.
the having to right click isn't too much of a problem but not being able to reply to mail is going to be a pain.
thanks for reading a long post, hopefully someone a bit more clued up that me can point me in the right direction.
cheers, pete.
p.s. going to bed now (uk)
    acer aspire 5335
    intel celeron 575
    1gb
pete
It might be as simple as a mouse driver. can you go start>search>type event viewer, and go to the mouse tab. id it listed there, and is it working properly? If it has a yellow triangle on it or ins't listed there you need to re-install the driver.
let us know the results and could you tell us more abt your computer and mouse. are you 32bit, or 64?
kwn
    Dell Inspiron E 1405
    [email protected]
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
morning zigzag, thanks for the reply.
its 32 bit with basic vista. acer aspire with synaptics touchpad v7.2.
strange thing with my problem is that its constant, some sections of some sites are always problems, others are no problem at all. this site i can get around without a hitch, but the wifes face book needs right clicks all the time.
i'm going to try the external mouse from my pc to see if anything changes.
cheers, pete.
    acer aspire 5335
    intel celeron 575
    1gb
nothing listed concerning the mousepad on the event viewer screen, and the same faults apply with my external mouse plugged in.
i was thinking it was something to do with different file types or sizes but when i've shown properties i can't see much difference between ones that will or won't open.
on the hotmail page the delete button at the top of my mail list works fine but the new mail button next to it won't do a thing ???
    acer aspire 5335
    intel celeron 575
    1gb
I'm pretty sure he meant the device manager not event viewer. In which case, it would be: start search > type device > choose device manager > accept UAC prompt, if prompted > under mouse or touchpad > any yellow triangles or gray boxes?
    HP
    Intel Neo
    2GB
    Intergrated Intel Graphics
    Integrated
    160GB
    Power Adapter
    Acer
    Touchpad
    Down: 16mb/s Up: 1.6mb/s
    I killed my HP Laptop :'(
no problems listed there either CH. thanks for the reply though. it tells me 'this device is working correctly'
i was going to try to go to ie7 from the current ie8 as i've read a few negative things about 8. not sure it will fix my problem, but may be worth a try ? any thoughts on this anyone ?
    acer aspire 5335
    intel celeron 575
    1gb
If this is a consistent issue with the same links then that would tend to eliminate the likelihood of a hardware issue.
I am beginning to suspect IE8, (as you are), but not an actual fault with IE but a possible security or similar setting that is preventing the left click from operating, depending on where the links lead - for example allowing links on the same site but not external links.
There is an item on the IE8 settings to re-set the application to defaults, this may help
you may want to open the No Add-ons, "Safe", version of IE8 and see if this helps.
If the Safe mode is OK then this would suggest that an add-on may be causing the issue.
    2 x 1920x1080 @50Hz
    Asus M5A78L-M USB3
    32GB [4x8GB] DDR3 1600 MHz
    Asus nVidia GTX750TI-OC-2GD5 (2GB DDR5)
    Samsung 32" TV
    Internal
    Crucial CT256MX100SSD1 256GB SSD,
    Seagate ST2000DM001-1CH1 2TB,
    External (USB3)
    Seagate Backup+ Hub BK SCSI Disk 8TB
    2.5/3.5 Hot Swap Cradle, USB3 + eSata (client HDDs)
    NAS 4TB
    68 MB Down 18.5 MB Up
just got back from work !
thanks for the reply barman. will give your suggestions a try.
i have a friend who does things with computers coming to have a play with it tomorrow hopefully he will get to the root of it. (i'm a mechanic and only go so far into these things before i sing for help)
will keep you all posted of any fixes that turn up, thanks again for all replies,
pete.
    acer aspire 5335
    intel celeron 575
    1gb
ok, fixed it and feel a little bit pleased with myself for doing so (mechanic remember) and also a bit embarrassed to own up to what the problem was.
brrrrrrrr (drum roll). . . . .the firewall settings !
the firewall was set to 'block pop up and pop under windows' one simple (left ha ha) click and all is well again.
thanks to all for trying to help, i'm sure if any of you had been here in person it wouldn't have taken you several days to fix !
simple things may be simple things but they sure can hide well from the unfamiliar !
cheers all, pete.
    acer aspire 5335
    intel celeron 575
    1gb
