Battery Not Charging!
shortmantuff
I own a Toshiba Satellite A215-S4757 laptop, and when I plug in, the battery light comes on indicating it is charging. After 3 or so seconds, the light turns off. At first I thought it was just something wrong with the light, but when I turned the laptop on, the battery says "Plugged in, not charging" It has never done this before. Any suggestions?
    2048MB DDR2 SDRAM
    ATI Radeon® X1200 128MB-319MB
    15.4” diagonal widescreen TruBrite®TFT LCD display at 1280x800 native resolution (WXGA)
    250GB (4200RPM); Serial ATA hard disk drive
Two possibilities - bad charger or bad battery. Hope for a bad charger, when is relatively cheap to replace. The cost of notebook batteries are outrageous. Also, see if there is a break in the charger wire by rotating the wire. If the light goes off and on, it's a break.
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Quietkey
    Dell Optical
    10 MBPS
The computer is running off of the AC Adapter as we speak though. Would it still be a bad charger? Right now, I'm using no battery, all AC Adapter.
    2048MB DDR2 SDRAM
Very, very true. It's not the charger. I have one notebook that runs off the charger as well. Battery is bad and I just use it as another PC. Well, portable in the sense I can take it to a hotel, but not using battery.
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Quietkey
    Dell Optical
    10 MBPS
I don't own a Sony computer though. That is for Sony.
    2048MB DDR2 SDRAM
Mea cupla. What is your battery part number?
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Quietkey
    Dell Optical
    10 MBPS
K000046330 WK726T Thats what one sticker says
Model NO. PA3534U-1BRS
PS Is it bad to remove your battery when it is plugged in to go from Battery Power to AC power?
    2048MB DDR2 SDRAM
Alright, so I talked to a Toshiba representative. My battery was at 99% when this happened. It just would stop charging. The representative said that the battery might shut off because it is overheating. She said to let it drain down to 50% and then try again. I did, and it works now. I'll let you know if it is a fluke and stops at 99% again. Otherwise, thanks for all the help.
This has never happened before. I wish I had one of those laptops that once the battery is charged fully, it uses AC power and saves battery life. That would be cool...but I dont. That's why I was worried.
    2048MB DDR2 SDRAM
Well, it did it again. Once it hits 99% it just stops charging. Usually continues to charge, even at 100%. I don't know what is happening, but I guess as long as my battery can still keep a charge, I can't complain.
    2048MB DDR2 SDRAM
Okay, it is getting worse basically every time I recharge it. It used to stop at 99%. Then it stopped at 98%. Now it's stopping at 97%. Have any of you heard of a battery doing this before?
    2048MB DDR2 SDRAM
