I'm struggling to find a clear answer on this. Within our environment, we've been ordering Dell PCs for quite some time. I've been told that about midway through the ordering of Dell GX620 Optiplexes that the cores went from single to dual.
In effect, I've been advised that these machines and, subsequently everything we've ordered since, are considered 64bit compatible because they have two 32bit cores.
Does that sound accurate? What I truly need to know is whether or not any of our PCs (Dell 745, 755 and 760 E8400 Core 2 Duo for desktop; P8400 for laptop) have 64bit hardware. If two 32bit cores mean that they're 64bit compatible, is that the same as being true 64bit?
And, last but not least, will 64bit compatible hardware (assuming it's different than 64bit hardware) run a 64bit OS like Windows 7?
Thanks in advance.
Thanks in advance.
