start up problems plz help
robin171
i am using vista ,,and my laptop is Asus f3t ,, everything was working fine..until i made some changes in the start up options.. disabling some..coz i thought it might increase my computer speed by disabling unwanted programs on start up.. this i found by typing ms config on start up... so when i disabled..and then restarted ..my laptop is totally blank, and but i hear the fans getting started up..and all..but the screen is totally blank. tried to remove the battery... switch on and off..but i see just the power lights on, just worried whether i did something wrong.any help would be appreciated.plz help.
robin
    asus f3t
    1gb
See if you can get in with safe mode. If so, use system restore to go back to the time that it worked.
Hit f8 during the boot.
dear richard,,thanks for replying me... but even pressing f8 doesnt work,, its totally blank..but the power is on..lights r working...i hear the fans sound...
plz help
    asus f3t
    1gb
plz help
    asus f3t
    1gb
robin
Make sure you monitor is connected properly. If everything is connected, you most likely ended a start up process that runs your display, and may have to call your computers manufacturer for them to either replace or fix it.
    Windows
    1GB
    ATI RADEON XPRESS 1100 Series
robin
dear skizzer..thank u for replying...but my comp..is a laptop..and of course everything is connected. the thing was i disabled some options in the start up.. programs..until then it worked well. now after restarting..i could find nothing. there is a blank screen,, so cant do anything. and pressing the f8 or f9 doesn't show anything still it is blank. please help if you have any solution.
    asus f3t
    1gb
Did you try the repair install with the DVD?
Get your computer manual, it will tell you how to restore just like the day you bought the computer. If a DVD came with the computer try that, too.
dear richard.. tried..to follow these..but i think you get what i say.. the screen is totally blank...but i hear the laptop starting up...lights on...even i hear the cd is running..but no sign on the screen... it is very blank.. i think i messed up ..disabled some vga configuration on start up options..accidently...
please help if any solution u know...
    asus f3t
    1gb
I understand exactly what you are saying and I am trying to do everything to get you going again. I know how you feel and I wish that I could do more. I will research and anything that I find I will give you, even if there is only a small chance that it will work. .
Robin
Rich has asked for help and you now have some of the best here. Can you please tell us your current situation.
Can you boot into safe mode?
Do you have either a vista dvd, or recovery dvd?
Do you have a backup we can restore from?
Have you restored msconfig back to default?
Let us Know
Ken
    Dell Inspiron E 1405
    [email protected]
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
Robin
Let us Know
Ken
still my laptop is blank as i said..because i cant get the screen to run in safe mode. i have a recovery asus dvd, and a (driver,utility) cd, and still stuck nothing more i could do... tried pressing f5 and n .. then f6 and n.. as i read in other websites... removed the battery and started again..still no sign.. the laptop is ok i think...coz the small green lights are on.. but the screen is blank ...am helpless..to find a solution.
please help me.. am typing this using another friends lap...
    asus f3t
    1gb
If all attempts to access the OS or Safe Mode have not worked I will think about the problem and advise you of any new ideas, sorry.
hello
when you disabled "stuff" was that from the "startup" tab in msconfig?
    acer aspire 6930
    3GB
    onboard
    onboard
    320GB
