Please Help with this problem.
doodlebug
Can someone please help me correct this problem, When I log on my computer, I get this same error message, it automaticaly reboots about 4 to 5 times.
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.1.7600.2.0.0.768.3
Locale ID: 1033
Additional information about the problem:
BCCode: a
BCP1: 19168D20
BCP2: 00000002
BCP3: 00000001
BCP4: 82EB63A9
OS Version: 6_1_7600
Service Pack: 0_0
Product: 768_1
Files that help describe the problem:
C:\Windows\Minidump\020910-32963-01.dmp
C:\Users\Vixy\AppData\Local\Temp\WER-66487-0.sysdata.xml
Read our privacy statement online:
Windows 7 Privacy Statement - Microsoft Windows
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
Please can someone help me - I dont know what to do!
I'm not sure if I did this correct, but I'm giving it my best shot. Thanks richc46.
You did it fine. You do have a bunch of them dont you. Unfortunately there are so many probable causes I can only think that there is a hardware problem possibily memory
I would download memtestx86 and run it for 5 passes
run a system file check
type cmd in search>right click and run as admin>sfc /scannow
If you are overclocking stop
Let us know the results
Ken
Code:
Microsoft (R) Windows Debugger Version 6.11.0001.404 X86
Loading Dump File [C:\Users\K\Desktop\New folder\013010-26395-01.dmp]
Symbol search path is: SRV*d:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 7 Kernel Version 7600 MP (2 procs) Free x86 compatible
Built by: 7600.16385.x86fre.win7_rtm.090713-1255
Machine Name:
Kernel base = 0x82e43000 PsLoadedModuleList = 0x82f8b810
Debug session time: Sat Jan 30 12:49:51.348 2010 (GMT-5)
System Uptime: 0 days 0:02:14.330
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck A, {8de89d8, 2, 0, 82eae91c}
Probably caused by : win32k.sys ( win32k!TimersProc+189 )
Followup: MachineOwner
1: kd> !analyze -v
IRQL_NOT_LESS_OR_EQUAL (a)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high.  This is usually
caused by drivers using improper addresses.
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: 08de89d8, memory referenced
Arg2: 00000002, IRQL
Arg3: 00000000, bitfield :
    bit 0 : value 0 = read operation, 1 = write operation
    bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status)
Arg4: 82eae91c, address which referenced memory
Debugging Details:
READ_ADDRESS: GetPointerFromAddress: unable to read from 82fab718
Unable to read MiSystemVaType memory at 82f8b160
 08de89d8
CURRENT_IRQL:  2
FAULTING_IP:
nt!KiInsertTimerTable+138
82eae91c 8b48f8          mov     ecx,dword ptr [eax-8]
CUSTOMER_CRASH_COUNT:  1
DEFAULT_BUCKET_ID:  VISTA_DRIVER_FAULT
BUGCHECK_STR:  0xA
PROCESS_NAME:  csrss.exe
TRAP_FRAME:  8af89b74 -- (.trap 0xffffffff8af89b74)
ErrCode = 00000000
eax=08de89e0 ebx=00000040 ecx=00000000 edx=8239b9f0 esi=807c8a80 edi=807c9a0c
eip=82eae91c esp=8af89be8 ebp=8af89c30 iopl=0         ov up ei ng nz ac pe cy
cs=0008  ss=0010  ds=0023  es=0023  fs=0030  gs=0000             efl=00010a97
nt!KiInsertTimerTable+0x138:
82eae91c 8b48f8          mov     ecx,dword ptr [eax-8] ds:0023:08de89d8=????????
Resetting default scope
LAST_CONTROL_TRANSFER:  from 82eae91c to 82e897eb
STACK_TEXT:
8af89b74 82eae91c badb0d00 8239b9f0 955f9e61 nt!KiTrap0E+0x2cf
8af89c30 82eae7aa 8239b9f0 000000a3 807c7120 nt!KiInsertTimerTable+0x138
8af89c44 82eae775 807c7120 000000a3 00000000 nt!KiInsertOrSignalTimer+0x14
8af89c74 82eb49c2 ffff63c0 ffffffff 00000000 nt!KiSetTimerEx+0x6a
8af89c94 9561924b 8239b9f0 ffff63c0 ffffffff nt!KeSetTimer+0x1b
8af89cc8 9556843c 00000004 0161feb8 9562c2ad win32k!TimersProc+0x189
8af89d04 95568586 00000004 00000002 82843400 win32k!RawInputThread+0x61f
8af89d18 9562c2c8 00000004 0161feb8 8af89d34 win32k!xxxCreateSystemThreads+0x4a
8af89d28 82e8642a 00000004 0161fef8 779e64f4 win32k!NtUserCallNoParam+0x1b
8af89d28 779e64f4 00000004 0161fef8 779e64f4 nt!KiFastCallEntry+0x12a
WARNING: Frame IP not in any known module. Following frames may be wrong.
0161fef8 00000000 00000000 00000000 00000000 0x779e64f4
STACK_COMMAND:  kb
FOLLOWUP_IP:
9561924b 5f              pop     edi
SYMBOL_STACK_INDEX:  5
SYMBOL_NAME:  win32k!TimersProc+189
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: win32k
IMAGE_NAME:  win32k.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4a5bc2a2
FAILURE_BUCKET_ID:  0xA_win32k!TimersProc+189
causes
Code:
012810-27175-01.dmp    1/28/2010 9:46:44 AM    IRQL_NOT_LESS_OR_EQUAL    0x0000000a    0x084d2c20    0x00000002    0x00000001    0x82ebfb59    ntkrnlpa.exe    ntkrnlpa.exe+467eb                    32-bit        C:\Users\K\Desktop\New folder\012810-27175-01.dmp    2    15    7600
013010-25350-01.dmp    1/30/2010 11:07:10 AM    IRQL_NOT_LESS_OR_EQUAL    0x0000000a    0x1b30a0d0    0x00000002    0x00000000    0x82eb891c    ntkrnlpa.exe    ntkrnlpa.exe+467eb                    32-bit        C:\Users\K\Desktop\New folder\013010-25350-01.dmp    2    15    7600
013010-26395-01.dmp    1/30/2010 10:51:08 AM    IRQL_NOT_LESS_OR_EQUAL    0x0000000a    0x08de89d8    0x00000002    0x00000000    0x82eae91c    win32k.sys    win32k.sys+99e61                    32-bit        C:\Users\K\Desktop\New folder\013010-26395-01.dmp    2    15    7600
013010-26863-01.dmp    1/30/2010 11:03:24 AM    IRQL_NOT_LESS_OR_EQUAL    0x0000000a    0x02951c58    0x00000002    0x00000001    0x82ea7b59    ntkrnlpa.exe    ntkrnlpa.exe+467eb                    32-bit        C:\Users\K\Desktop\New folder\013010-26863-01.dmp    2    15    7600
020410-25802-01.dmp    2/4/2010 8:03:50 PM    IRQL_NOT_LESS_OR_EQUAL    0x0000000a    0x1bb69800    0x00000002    0x00000000    0x82eb091c    win32k.sys    win32k.sys+bd47f                    32-bit        C:\Users\K\Desktop\New folder\020410-25802-01.dmp    2    15    7600
020410-26286-01.dmp    2/4/2010 2:11:22 PM    IRQL_NOT_LESS_OR_EQUAL    0x0000000a    0x09337d38    0x00000002    0x00000000    0x82eb491c    halmacpi.dll    halmacpi.dll+1aaf0                    32-bit        C:\Users\K\Desktop\New folder\020410-26286-01.dmp    2    15    7600
020410-26457-01.dmp    2/4/2010 7:58:00 PM    IRQL_NOT_LESS_OR_EQUAL    0x0000000a    0x0ab5b274    0x00000002    0x00000000    0x82ea4d8a    halmacpi.dll    halmacpi.dll+3479                    32-bit        C:\Users\K\Desktop\New folder\020410-26457-01.dmp    2    15    7600
020410-27346-01.dmp    2/4/2010 2:06:08 PM    IRQL_NOT_LESS_OR_EQUAL    0x0000000a    0x08ba0524    0x00000002    0x00000000    0x82e7bd8a    halmacpi.dll    halmacpi.dll+3479                    32-bit        C:\Users\K\Desktop\New folder\020410-27346-01.dmp    2    15    7600
020510-25615-01.dmp    2/5/2010 3:42:58 PM    IRQL_NOT_LESS_OR_EQUAL    0x0000000a    0x0934fcd8    0x00000002    0x00000000    0x82e7291c    ntkrnlpa.exe    ntkrnlpa.exe+467eb                    32-bit        C:\Users\K\Desktop\New folder\020510-25615-01.dmp    2    15    7600
020510-25833-01.dmp    2/5/2010 11:55:02 PM    IRQL_NOT_LESS_OR_EQUAL    0x0000000a    0x1ab65f78    0x00000002    0x00000000    0x82eb291c    ntkrnlpa.exe    ntkrnlpa.exe+467eb                    32-bit        C:\Users\K\Desktop\New folder\020510-25833-01.dmp    2    15    7600
020510-26488-01.dmp    2/5/2010 3:36:04 PM    IRQL_NOT_LESS_OR_EQUAL    0x0000000a    0x0835f454    0x00000002    0x00000000    0x82e7ad8a    afd.sys    afd.sys+1032                    32-bit        C:\Users\K\Desktop\New folder\020510-26488-01.dmp    2    15    7600
020510-26785-01.dmp    2/5/2010 3:49:00 PM    IRQL_NOT_LESS_OR_EQUAL    0x0000000a    0x1a647278    0x00000002    0x00000000    0x82e7891c    ntkrnlpa.exe    ntkrnlpa.exe+467eb                    32-bit        C:\Users\K\Desktop\New folder\020510-26785-01.dmp    2    15    7600
020910-26083-01.dmp    2/9/2010 11:18:22 AM    IRQL_NOT_LESS_OR_EQUAL    0x0000000a    0x1a897dec    0x00000002    0x00000000    0x82e7dd8a    dxgmms1.sys    dxgmms1.sys+d83b                    32-bit        C:\Users\K\Desktop\New folder\020910-26083-01.dmp    2    15    7600
020910-26613-01.dmp    2/9/2010 8:04:30 PM    IRQL_NOT_LESS_OR_EQUAL    0x0000000a    0x08492040    0x00000002    0x00000000    0x82ebe91c    ntkrnlpa.exe    ntkrnlpa.exe+467eb                    32-bit        C:\Users\K\Desktop\New folder\020910-26613-01.dmp    2    15    7600
020910-26847-01.dmp    2/9/2010 11:14:06 AM    IRQL_NOT_LESS_OR_EQUAL    0x0000000a    0x087a00d4    0x00000002    0x00000000    0x82eb6d8a    amdk8.sys    amdk8.sys+1bb6                    32-bit        C:\Users\K\Desktop\New folder\020910-26847-01.dmp    2    15    7600
020910-27970-01.dmp    2/9/2010 5:46:28 PM    IRQL_NOT_LESS_OR_EQUAL    0x0000000a    0x1b1f52fc    0x00000002    0x00000000    0x82eb2d8a    tcpip.sys    tcpip.sys+f9f02                    32-bit        C:\Users\K\Desktop\New folder\020910-27970-01.dmp    2    15    7600
020910-32963-01.dmp    2/9/2010 5:13:22 PM    IRQL_NOT_LESS_OR_EQUAL    0x0000000a    0x19168d20    0x00000002    0x00000001    0x82eb63a9    halmacpi.dll    halmacpi.dll+5ba9                    32-bit        C:\Users\K\Desktop\New folder\020910-32963-01.dmp    2    15    7600
021010-25443-01.dmp    2/10/2010 3:12:40 PM    IRQL_NOT_LESS_OR_EQUAL    0x0000000a    0x19b64b98    0x00000002    0x00000000    0x82ebc9fc    ntkrnlpa.exe    ntkrnlpa.exe+4685b                    32-bit        C:\Users\K\Desktop\New folder\021010-25443-01.dmp    2    15    7600
021010-25911-01.dmp    2/10/2010 3:22:52 PM    IRQL_NOT_LESS_OR_EQUAL    0x0000000a    0x1921c730    0x00000002    0x00000001    0x82ebd541    ntkrnlpa.exe    ntkrnlpa.exe+4685b                    32-bit        C:\Users\K\Desktop\New folder\021010-25911-01.dmp    2    15    7600
021010-26161-01.dmp    2/10/2010 2:34:58 PM    IRQL_NOT_LESS_OR_EQUAL    0x0000000a    0x02f7f788    0x00000002    0x00000000    0x82ebcd8a    amdk8.sys    amdk8.sys+1bb6                    32-bit        C:\Users\K\Desktop\New folder\021010-26161-01.dmp    2    15    7600
021010-26800-01.dmp    2/10/2010 3:15:58 PM    IRQL_NOT_LESS_OR_EQUAL    0x0000000a    0x0862dbb0    0x00000002    0x00000000    0x82e7b9fc    ntkrnlpa.exe    ntkrnlpa.exe+4685b                    32-bit        C:\Users\K\Desktop\New folder\021010-26800-01.dmp    2    15    7600
021010-27222-01.dmp    2/10/2010 2:38:14 PM    IRQL_NOT_LESS_OR_EQUAL    0x0000000a    0x18def0d0    0x00000002    0x00000000    0x82e7791c    halmacpi.dll    halmacpi.dll+5cca                    32-bit        C:\Users\K\Desktop\New folder\021010-27222-01.dmp    2    15    7600
012910-32838-01.dmp    1/29/2010 11:54:32 PM    KMODE_EXCEPTION_NOT_HANDLED    0x0000001e    0xc0000005    0x8ae5acf0    0x00000000    0x00000000    ntkrnlpa.exe    ntkrnlpa.exe+dcd10                    32-bit        C:\Users\K\Desktop\New folder\012910-32838-01.dmp    2    15    7600
013010-27892-01.dmp    1/30/2010 10:42:02 AM    NTFS_FILE_SYSTEM    0x00000024    0x001904fb    0x99dc76f8    0x99dc72d0    0x872ce4ab    Ntfs.sys    Ntfs.sys+1a4ab                    32-bit        C:\Users\K\Desktop\New folder\013010-27892-01.dmp    2    15    7600
020510-27206-01.dmp    2/5/2010 11:58:18 PM    NTFS_FILE_SYSTEM    0x00000024    0x001904fb    0x9e4cda78    0x9e4cd650    0x87345f18    Ntfs.sys    Ntfs.sys+a8f18                    32-bit        C:\Users\K\Desktop\New folder\020510-27206-01.dmp    2    15    7600
020710-27175-01.dmp    2/7/2010 11:55:20 AM    NTFS_FILE_SYSTEM    0x00000024    0x001904fb    0x9115c4d4    0x9115c0b0    0x8723976f    Ntfs.sys    Ntfs.sys+f76f                    32-bit        C:\Users\K\Desktop\New folder\020710-27175-01.dmp    2    15    7600
020310-22620-01.dmp    2/3/2010 2:50:54 PM    PAGE_FAULT_IN_NONPAGED_AREA    0x00000050    0x8afffc08    0x00000001    0x82e9c662    0x00000000    halmacpi.dll    halmacpi.dll+5ba9                    32-bit        C:\Users\K\Desktop\New folder\020310-22620-01.dmp    2    15    7600
020410-25942-01.dmp    2/4/2010 2:26:14 PM    PAGE_FAULT_IN_NONPAGED_AREA    0x00000050    0x9a264004    0x00000000    0x830d131a    0x00000000    fltmgr.sys    fltmgr.sys+b530                    32-bit        C:\Users\K\Desktop\New folder\020410-25942-01.dmp    2    15    7600
020910-26535-01.dmp    2/9/2010 5:08:10 PM    PAGE_FAULT_IN_NONPAGED_AREA    0x00000050    0xf482ec1c    0x00000001    0x95528ea4    0x00000002    ntkrnlpa.exe    ntkrnlpa.exe+858e3                    32-bit        C:\Users\K\Desktop\New folder\020910-26535-01.dmp    2    15    7600
020910-26910-01.dmp    2/9/2010 11:09:04 AM    PAGE_FAULT_IN_NONPAGED_AREA    0x00000050    0xffc006c8    0x00000000    0x95dec011    0x00000000    win32k.sys    win32k.sys+cd615                    32-bit        C:\Users\K\Desktop\New folder\020910-26910-01.dmp    2    15    7600
013010-25396-01.dmp    1/30/2010 11:26:54 AM    ATTEMPTED_WRITE_TO_READONLY_MEMORY    0x000000be    0x82e83067    0x02e83121    0xa2a7bbec    0x0000000b    ntkrnlpa.exe    ntkrnlpa.exe+858e3                    32-bit        C:\Users\K\Desktop\New folder\013010-25396-01.dmp    2    15    7600
012810-31449-01.dmp    1/28/2010 9:34:24 AM    DRIVER_IRQL_NOT_LESS_OR_EQUAL    0x000000d1    0x9dbe7f6c    0x00000002    0x00000000    0x8deed74a    IDSvix86.sys    IDSvix86.sys+4274a                    32-bit        C:\Users\K\Desktop\New folder\012810-31449-01.dmp    2    15    7600
021010-27237-01.dmp    2/10/2010 3:02:16 PM    DRIVER_IRQL_NOT_LESS_OR_EQUAL    0x000000d1    0x0ac8f754    0x00000002    0x00000000    0x876a041f    tcpip.sys    tcpip.sys+85732                    32-bit        C:\Users\K\Desktop\New folder\021010-27237-01.dmp    2    15    7600
013010-28470-01.dmp    1/30/2010 10:45:02 AM    CRITICAL_OBJECT_TERMINATION    0x000000f4    0x00000003    0x82b69b38    0x82b69ca4    0x8305fd50    ntkrnlpa.exe    ntkrnlpa.exe+dcd10                    32-bit        C:\Users\K\Desktop\New folder\013010-28470-01.dmp    2    15    7600
020910-26020-01.dmp    2/9/2010 8:00:00 PM    ATTEMPTED_EXECUTE_OF_NOEXECUTE_MEMORY    0x000000fc    0xa1d68d50    0x1c075963    0xa1d68c98    0x00000002    tunnel.sys    tunnel.sys+15590                    32-bit        C:\Users\K\Desktop\New folder\020910-26020-01.dmp    2    15    7600
020310-33103-01.dmp    2/3/2010 1:24:30 AM        0x00000124    0x00000000    0x854a98fc    0x00000000    0x00000000    ntoskrnl.exe    ntoskrnl.exe+322493                    32-bit        C:\Users\K\Desktop\New folder\020310-33103-01.dmp    2    15    7600
020410-27268-01.dmp    2/4/2010 2:02:56 PM        0x00000135    0xc0000005    0x9eb23160    0x8ca58f2c    0x8bf127b0    BHDrvx86.sys    BHDrvx86.sys+37f2c                    32-bit        C:\Users\K\Desktop\New folder\020410-27268-01.dmp    2    15    7600
020510-26083-01.dmp    2/5/2010 3:33:12 PM        0x00000135    0xc0000005    0xa3387160    0x8dae9f2c    0x8c293e60    BHDrvx86.sys    BHDrvx86.sys+37f2c                    32-bit        C:\Users\K\Desktop\New folder\020510-26083-01.dmp    2    15    7600
020510-26644-01.dmp    2/5/2010 11:51:54 PM        0x00000135    0xc0000005    0x99753160    0x8dd03f2c    0x89007628    BHDrvx86.sys    BHDrvx86.sys+37f2c                    32-bit        C:\Users\K\Desktop\New folder\020510-26644-01.dmp    2    15    7600
020710-27362-01.dmp    2/7/2010 12:07:14 PM        0x00000135    0xc0000005    0xa59c3460    0x8e06cf2c    0x8bc95df0    BHDrvx86.sys    BHDrvx86.sys+37f2c                    32-bit        C:\Users\K\Desktop\New folder\020710-27362-01.dmp    2    15    7600
020910-26676-01.dmp    2/9/2010 11:32:56 AM        0x00000135    0xc0000005    0x9db03160    0x8e0cff2c    0x8c86d510    BHDrvx86.sys    BHDrvx86.sys+37f2c                    32-bit        C:\Users\K\Desktop\New folder\020910-26676-01.dmp    2    15    7600
021010-31325-01.dmp    2/10/2010 2:31:28 PM        0x00000135    0xc0000005    0xa0ad3160    0x8d384f2c    0x8b93a828    BHDrvx86.sys    BHDrvx86.sys+37f2c                    32-bit        C:\Users\K\Desktop\New folder\021010-31325-01.dmp    2    15    7600
012910-27799-01.dmp    1/29/2010 11:45:58 PM    SYSTEM_THREAD_EXCEPTION_NOT_HANDLED    0x1000007e    0xc0000005    0x02210bb2    0x95108b30    0x95108710    HSX_DPV.sys    HSX_DPV.sys+70f2                    32-bit        C:\Users\K\Desktop\New folder\012910-27799-01.dmp    2    15    7600
013010-29109-01.dmp    1/30/2010 10:58:06 AM    SYSTEM_THREAD_EXCEPTION_NOT_HANDLED    0x1000007e    0xc0000005    0x8f990de5    0x893e8b60    0x893e8740    dxgmms1.sys    dxgmms1.sys+25de5                    32-bit        C:\Users\K\Desktop\New folder\013010-29109-01.dmp    2    15    7600
020910-26972-01.dmp    2/9/2010 5:02:14 PM    SYSTEM_THREAD_EXCEPTION_NOT_HANDLED    0x1000007e    0xc0000005    0x82eb0f03    0xa2f6ac44    0xa2f6a820    ntkrnlpa.exe    ntkrnlpa.exe+6df03                    32-bit        C:\Users\K\Desktop\New folder\020910-26972-01.dmp    2    15    7600
013010-25162-01.dmp    1/30/2010 11:11:14 AM    KERNEL_MODE_EXCEPTION_NOT_HANDLED    0x1000008e    0xc0000005    0x830ba777    0x9b6ab9ec    0x00000000    ntkrnlpa.exe    ntkrnlpa.exe+277777                    32-bit        C:\Users\K\Desktop\New folder\013010-25162-01.dmp    2    15    7600
020410-26223-01.dmp    2/4/2010 7:55:00 PM    KERNEL_MODE_EXCEPTION_NOT_HANDLED    0x1000008e    0xc0000005    0x8cc6ea33    0x937a9a58    0x00000000    SYMTDIV.SYS    SYMTDIV.SYS+18a33                    32-bit        C:\Users\K\Desktop\New folder\020410-26223-01.dmp    2    15    7600
020510-25521-01.dmp    2/5/2010 11:50:38 PM    KERNEL_MODE_EXCEPTION_NOT_HANDLED    0x1000008e    0xc000001d    0x8e498553    0x82f5fac8    0x00000000    tunnel.sys    tunnel.sys+3553                    32-bit        C:\Users\K\Desktop\New folder\020510-25521-01.dmp    2    15    7600
020910-27502-01.dmp    2/9/2010 5:05:06 PM    KERNEL_MODE_EXCEPTION_NOT_HANDLED    0x1000008e    0xc0000005    0x8c3d4d31    0xa4d19528    0x00000000    Ironx86.SYS    Ironx86.SYS+9d31                    32-bit        C:\Users\K\Desktop\New folder\020910-27502-01.dmp    2    15    7600
021010-26613-01.dmp    2/10/2010 3:58:02 PM    KERNEL_MODE_EXCEPTION_NOT_HANDLED    0x1000008e    0xc0000005    0x8cccb6f6    0xa1df0b34    0x00000000    SYMEVENT.SYS    SYMEVENT.SYS+136f6                    32-bit        C:\Users\K\Desktop\New folder\021010-26613-01.dmp    2    15    7600
OLD DRIVERS
Code:
mdmxsdk.sys        0x97d65000    0x97d68180    0x00003180    0x449716a3    6/19/2006 4:26:59 PM
secdrv.SYS        0x97c00000    0x97c0a000    0x0000a000    0x45080528    9/13/2006 8:18:32 AM
xaudio.sys        0x97c17000    0x97c1f000    0x00008000    0x456cd802    11/28/2006 7:44:50 PM
HSX_CNXT.sys        0x82133000    0x821e7000    0x000b4000    0x45789df6    12/7/2006 6:04:22 PM
HSXHWAZL.sys        0x93d85000    0x93dc2000    0x0003d000    0x45789e02    12/7/2006 6:04:34 PM
HSX_DPV.sys        0x82030000    0x82133000    0x00103000    0x45789e52    12/7/2006 6:05:54 PM
SynTP.sys        0x94db4000    0x94dde980    0x0002a980    0x45a7f838    1/12/2007 4:06:00 PM
rimsptsk.sys        0x8d7e8000    0x8d7fc000    0x00014000    0x45b5bbe3    1/23/2007 2:40:19 AM
rixdptsk.sys        0x93c0a000    0x93c5b000    0x00051000    0x45b5c14f    1/23/2007 3:03:27 AM
PxHelp20.sys        0x871dd000    0x871e5b80    0x00008b80    0x45c3abed    2/2/2007 4:23:57 PM
nvsmu.sys        0x8e77c000    0x8e77ef00    0x00002f00    0x45d5d2c7    2/16/2007 10:50:31 AM
rimmptsk.sys        0x8e7e9000    0x8e7f8000    0x0000f000    0x45dfd03d    2/24/2007 12:42:21 AM
CHDART.sys        0x93d11000    0x93d3d000    0x0002c000    0x461ecf44    4/12/2007 7:31:00 PM
nvm62x32.sys        0x93c5b000    0x93cafc80    0x00054c80    0x48f8fcf7    10/17/2008 4:00:39 PM
    Dell Inspiron E 1405
    [email protected]
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
