I have a problem my c drive. Please help.
preety
Hi.......I m using vista business.I have a problem my c drive is 23.44 gb out of which on 12.75 g.b i m able to use.the rest is showing free space in disk management now what do i do?
Please help!!!:confused:
Hi !
I have uploaded my disk management in the attachment please help now as i m not being able to extend my c drive,and i dont know y but my vista is also working very slow.Please suggest
Thanks,
Preety
You should be able to right-click on your C drive in Disk Management and extend it to the end of contiguous free space. Are you saying that this doesn't work? Is the "Extend volume..." menu item grayed-out?
    Home Grown Desktop
    Intel(R) Core(TM)2 CPU 6600 @ 2.40GHz
    ASUS P5B-E
    3006 MB
    NVIDIA GeForce 8400 GS 512MB
    Motherboard - SoundMax
    ViewSonic VX2235wm / Dell 17" Generic PnP Anolog
    1680 x 1050 x 4294967296 colors / 1024 x 768
    3 x ST3250620AS 250GB SATA IDE
    1 x WDC WD1200JD-00GBB0 120 GB SATA IDE
    Enerrmax 535W All-in-one SLI 20/24+6+
    Antec Sonata
    Antec 12cm SmartCool
    Logitech LX710
    Logitech MX100 Laser
    Bell Canada DSL 12MBps (supposedly)
    2 x HP Pavilion 9700v Laptops
im trying to extend my c drive.. it says a total of 500GB but there is 54GB that is unallocated and so i wanted to bring that back to my C drive, by "extending the volume"
problem is under disk management it doesnt let me, its gray out. i want to know if theres a program for free that would let me do that, i tried gparted live CD but it didnt work.
any recommendations,
"partition wizard home edition">>??
    AMD/GIGABYTE
    AMD Athlon(tm) 64 X2 Dual Core Processor 6000+ (2 CPUs), ~3.
    Gigabyte GA-M57SLI-S4 (rev. 2.0)
    2048MB RAM
    NVIDIA GeForce 8600 GT
    SyncMaster T220/T220G,SyncMaster Magic T220/T220G(Digital)
    1680 by 1050 pixels
    Seagate ST310003 40AS SCSI Disk Device
    Western Digital WDC WD50 00AAJS-00YFA SCSI Disk Device
    Thermaltake 500W
    VERY FAST>>>>!!!!
    Optiarc DVD RW AD-7191S SCSI CdRom Device
If I'm understanding your initial post correctly, you're getting conflicting information. One route, once suggested to me by a professional much more skilled than I, was to run SeaGate SeaTools for Windows. Even if your drive is NOT that brand, it will offer good tests. Lavalys (company) makes Everest, as well, a PHENOMENAL diagnostic software suite that is pretty handy. NOTE: If you use it, go to "Reports," "Generate System Report" (or full report,) "Save as TXT," (Save to desktop,) then you can uninstall the software.
With all the oddities out of the way (bear with me, I'm a little tired and that all may have been moot...,) let's look at the partition situation.
At risk of being tarred-n-feathered by everyone, I grabbed a rather nice summary from another site which nicely explains what Partition Magic CAN'T do!
In my humble opinion, it's all about the less-third-party-software-the-better, unless, of course, it's convenient or time-saving. I suppose it's balance.(?)
Below is the URL. Hopefully this aides in your efforts!
How to resize a partition in Windows Vista | Vista Rewired
Erik
    Dell
    Intel Core i7 820QM 1.73GHz "Clarksfield" (8 Threads)
    Dell Inc. 0874P6 (U2E1)
    4.0GB Dual-Channel DDR3 @ 661MHz (9-9-9-24)
    ATI Mobility Radeon HD 5400 Series
    (SoundMAX) IDT High Definition Audio
    15"+ Standard Dell Studio 1558 LCD monitor.
    1024 x 768
    (x2) 1TB WD "Elements" External HDD + (x1) 1.5TB WD "Elements) External HDD; 500GB Solid State Storage on laptop.
    N/A Notebook
    N/A
    External (NON-USB!) NZXT CRYO-S (X) Silver. ICE COLD.
    Standard, non-10-key, no fancy backlighting.
    Good 'ol reliable USB 2.0 Microsoft 3-button mouse.
    16 Mbps w/ Aaris DOCSIS 3.0-compliant modem
    Gigabit LAN. Tight network security. (Hopes of getting a Linksys 4-Port Gigabit Security Router with VPN!) Disabled WiFi/Wireless hardware; don't believe in the concept. If I did, would use draft-N adapter.
maybe i must be tired because you lost me with uninstalling programs and all the EXTRA stuff you said.
    AMD/GIGABYTE
    2048MB RAM
    1680 by 1050 pixels
    Thermaltake 500W
    VERY FAST>>>>!!!!
I apologize; the link at the bottom helps explain it better than I could.
The previous posts were a bit difficult to interperet; I simply offered some ideas for diagnostic utilities if options were missing or unavailable.
I am again, sorry, for any long-windedness or confusion I caused!
    Dell
    1024 x 768
    N/A Notebook
    N/A
lol, no problem, what do you think about that unallocated space on my primary drive, do you think i can somehow add it to my c partition.
    AMD/GIGABYTE
    2048MB RAM
    1680 by 1050 pixels
    Thermaltake 500W
    VERY FAST>>>>!!!!
