Solved Copy/Paste does not work HELP!
Welcome,
How are you trying to do it? There are several ways.
Hello richc46 - thank you for replying
I do it several ways - I highlight the text, right click and press ''copy''
but when I try to paste in the intented location ''paste'' does not appear. (cannot be clicked - not bold)
I also use control C and control V - does not work either
Is there another way and/or a solution?
Talk to me, how and when did this start?
Ok let me think
Try this. Go to search. Type CMD Do not hit enter. Rather right click and run as administrator.
In the cmd prompt type this sfc /scannow
Tell me what happens.
I ran it and this is the result:
Verification 100 percent complete
Windows Resource Protection found corrupt files but was unable to fix them.
Details included in CBS.Log windir\logs\CBS\CBS.log For example C:\Windows\Logs\CBS\CBS/log
Run several more times. Sometimes not fixed the first shot.
Try 3 times, but I think this road is a dead end.
If the above does not work and doubt if it will try this
Run an antivirus scan.
download and run malwarbytes
http://www.malwarebytes.org/mbam.php
Then try another browser. Firefox and Chrome are nice. I lean toward Chrome.
Dagurl,
Your post is the first one that I saw this morning, a great way to start the day. Helping on the boards, here, has 2 big benefits; I learn as I teach and the good feeling of being able to help others. I was able to acheive both in this situation and that makes me happy. Let me give you one more piece of advice, its free, too. Everything is working great, now. Make a copy of your hard drive, put it away and forget about it. Once a week make a system restore point. When you have a small problem, you can fix it with the System Restore, if the problem is much larger you can go back to the image that you made and put away. The downside if you do this is that you do not have to return to the Forum; but we rather have you here sharing your own knowledge than trying to solve problems. Take care.
Hey! Sorry, I have not seen your response until now.
Your help was highly appreciated and I think its a great thing you do here.
I will take your advice into consideration :)
