need help for my dual boot problem .
  1. #1
    Vista Home Premium 32bit.
    Local Time: 09:39 AM
    hello
    i am trying to make my pc dual boot vista, 7 and xp.
    i already installed windows vista home premium first in the first partition.
    then i want to install w7 in the next partition, and xp in the last one.
    my QUESTION is how to view all the 3 option in rebooting so i can log to any of them without any booting errors?
    by the way my machine is toshiba portege m800
    thnx.
  2. #2
    Bare Foot Kid's Avatar
    Technophile Wannabe
    The Lowcountry
    Vista 64-bit Ultimate Win7 64-bit Ultimate XP SP3 32-bit Pro
    Local Time: 09:39 PM
    usa us south carolina
    Re: need help for my dual boot problem .
    Hello degeniuss.
    The way I would do it is to install XP second then Windows 7 last so it can control the boot files; get XP installed then when it's booting, install W_7, you will not be able to boot to Vista after the XP is installed but after Windows 7 is installed you will get a screen at boot like the one below to choose which OS to boot.
    Vista first, first partition; XP second, third partition; W_7 third, second partition.
    click to enlarge
    PS, please don't use such big type/font in future.
  3. #3
    theog's Avatar
    Senior Member
    uk Hampshire
    vista home premium 32bit
    Local Time: 02:39 AM
    uk
    Use EasyBCD to setup the Windows boot manager, when you have installed all three OS.
    You can Use EasyBCD 2.0 in Win 7, Vista, & Win XP.
    Download EasyBCD 2.0.1 - NeoSmart Technologies
    OR
    1) Install Win XP, first.
    2) Install Vista, second
    3) install Windows 7, last.
    No need to setup Windows boot manager.
    Dual Boot Installation with Windows 7 and XP - Windows 7 Forums
    Dual Boot Installation with Windows 7 and Vista - Windows 7 Forums
    Dual Boot Installation with Windows Vista and XP
  4. #4
      Thread Starter
    i already installed vista first cuz it is my pc windows second i inisaled xp in the second partition D: but i got error loading xp after i displaied booting options. i want first to get me rid of this problem so i can boot to both vista and xp with no problems then i can inistall windows 7. any idea how to remove this problem (xp booting error)
    thnx.
  5. #5
    theog's Avatar
    Senior Member
    uk Hampshire
    uk
Dual Boot Problem rcenker General Discussion 5 30 Aug 2008
Dual Boot problem A J Ricaud Vista installation & setup 2 16 Feb 2008
Dual Boot Problem - Misplaced Boot Sector RoboDude Vista General 1 15 Jun 2006
Dual Boot Problem RoboDude Vista General 0 15 Jun 2006
Dual Boot Problem - Misplaced boot sector RoboDude Vista General 0 15 Jun 2006
