Solved At what temperature does an average CPU and GPU become too hot?
niemiro
Banned
Hello all!
Some of you may know me. Like my software and WinSxS (I love the way WinSxS all fits together!) but am utterly clueless about the hardware. Please forgive me this question!
I have a DESKTOP PC which is NOT overclocked in any way. It is reasonably powerful (see specs) and is a Dell. However, it is used to the extremes of its ability - regularly.
I would just like to ask you what the temperatures you would consider good, warm, and hot for both the GPU and CPU. I know the GPU can get quite hot, but I would please like to know how hot, so that I can learn.
I have a feeling that mine are quite hot. Most of the time I get:
CPU: 52 degrees Centigrade (C)
GPU: 128 C
These seem awfully hot. Putting my hand on the GPU plastic casing after use makes me think that these are not anomalous!
Thanks so much in advance!
Richard
EDIT: All of the fans have been confirmed as working, and it has good airflow all around, and always has had.
    Dell XPS 420
    Stock Dell 0TP406
    4 gb (DDR2 800) 400MHz
    1600 x 1200 and 1280 x 1204
    1 x 640Gb (SATA 300)
    1 x 1Tb (SATA 600)
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
Hello Richard, I am not really knowledgeable in this area & can only reflect on my own research so that i can monitor my own temps which basically indicates 70 degrees C and below in both cases as being comfortable temps.
In posts i have read concern is usually expressed in 80c+, your CPU looks fine mine runs at 50-65 & max 72c under heavy load. I use Core temp to monitor which also has overheat protection
http://www.alcpu.com/CoreTemp/
The tjmax is the CPU manufacturers max temp (assume critical) & safe temps to be 15c-20c below this.
As far as your GPU it looks extremely hot but i do not have a solution for you other than cleaning & extra cooling which i am sure you are already aware of. (my desktop has settings in the BIOS for the fan)
Here are my temps which are for a laptop;
    Hewlett Packard, compaq presario CQ60-305AU
    AMD Athlon QI-46 2.1 Ghz
    Wistron 303C
    2048 Mb DDR2 SD Ram
    NVidea GE Go Force 8200M G / 256Mb dedicated grapics memory
    MCP78S NVidea High definition
    15.6" High Definition Brightview Widescreen
    1336x768
    Toshiba MK2555GSX ATA
    Synaptics PS2/Touchpad
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    1x 180GB Intel 530 series SSD
    1 x 120GB Hitachi 5400rmp
    Medium for New Zealand
    Only ever used a laptop.
    Also use USB Freeview TV Card
    Lenovo Docking Station
    External Speakers
    Other bits a pieces as needed
Okay, i do know some about temps, and your cpu is above average, but okay if thats load.
BUT your gpu is overheating. About 105C is tops on a gpu. It'll start to throttle at that temp, and shut down over 110C! ATIs might e abit hotter at shutdown, but not much.
Your problem is airflow. Dells and factory prebuilts have horrible airflow. So if you can't remove the heat you just store it.
My system is an oc'd q6600 with a high Vcore of 1.36V and 2 gtx 260s overclocked. All in an Antec 900 case.
Great airflow, and in the right spots.. my gpu folds 24/7 and sits at 70-77C depending on projects. 3dVantage only hits 65C
My cpu, with aftermarket cooler will peak at 66C, but I need to reTIM it, as its 3yrs old.
Heres mine running prime95 at max power/heat mode... its 57C.
The max temp was achieved on a linX run, which is more heat inducing.
Your biggest issue is dells SUCK for changing cases, and i think thats your only way to cool it off. Try run ning sideless and see how things go.
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
At the very beginning of the day, this is how it looks. As you can see, it is good. However, the CPU climbs very slightly under load (no issue) but the GPU just climbs and climbs. Anyway, thank you all so, so much for all of the advice. I shall currently monitor the situation, and think about better cooling/different case (maybe an excuse for some new components as well)
Richard
    Dell XPS 420
    Stock Dell 0TP406
    1 x 1Tb (SATA 600)
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
Biggest issue is Dell uses their own screw pattern...
Your temps on first boot look good, and normal.. So its very possible its just built up heat.
I shall see how it goes for the moment. Thanks for all of the info, you beast this stuff! Anyway, congrats on getting Guru!
    Dell XPS 420
    Stock Dell 0TP406
    1 x 1Tb (SATA 600)
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
Good advise to try sideless! Just keep it clean.
    Intel e5300 2.6GHz
    ASRock G41M-LE
    OCZ 4 gig 800 MHz
    onboard 4500 GTX
    Diamond XS 7.1
    19" Insignia HDTV
    60 Hertz
    Seagate 500 gig 7200 rpm, WD Green 5400 rpm 800 gig
    550 Rocketfish
    Xion Solaris
    Skythe Katana III
    eMachines
    Logiteck wireless lazer
    3.5 WiFi
    Line in to Yamaha RX-V465 HT receiver, Infinity RS1001 fronts& rear, Cambridge SoundWorks center, Yamaha YST-SW216 subwolf
Hello all!
GPU: 128 C
Richard
Every processor has its own temperature average, however I wanted to add one point to what the guys were saying that in case if your CPU temp is overheating and starts making pc hangs and other issues, you may want to read about how to deal with this issue from the below link:
How to deal with my cpu overheating?
and
Cleaning the CPU fan did not solve the overheating!
best wishes
when I got worried about temp and other things I was told to download this little snazzy program. Dont know if you have another version of it from another outlet but I use this one. just gives me a state of mind so I know what my fans are up to :P
SpeedFan - Download
I separate temps out to three zones:
less than 45C: cool
46-59C: warm
60C+: hot
and anything about 80C is dangerously hot, it wouldn't last more than few months running every day at that kind of temp. my HP laptop didn't, the graphics was running 70-88C all the time. it was only lightly used- less than 500 hours across 2 years- the GPU killed itself.
my hardware temps:
right now the cpu's running a bit warm only because I'm not exactly at idle right now, got anime, windows update, hl2, and Defraggler running.
but you can see when it was at idle how cool it got- down to just 30C ~ a few degrees above room temp.
    DIY
    Intel i7 920
    MSI X58 Platinum
    12 GB (6x2GB) DDR3-1600
    MSI Twin Frozr nVidia GeForce GTX 560 TI
    Creative Sound Blaster X-Fi Titanium Pro
    ASUS VW266h 25.5" LCD, Acer S211HL 21" LED
    1920x1200 & 1920x1080
    OCZ RevoDrive 3 X2 PCIE SSD (primary)
    Seagate Barracuda 1.5TB
    Hitachi SATA II 1 TB
    Samsung SATA II 2 TB
    Corsair TX 850 watt
    Antec 900
    air
    IBM Model M
    Microsoft Intellimouse Optical 1.1 USB
    20 mbps
Welcome to the forum, but my stystems defy your statement.... Plus different architctures run differently.
80C on an amd or intel 775 is dangerous, but on a "i" chip 80's hot but not dangerous.
70-80C on a gpu won't kill it, mine alol run there running folding at home. My laptop games at 100C for the last 3 yrs.
GPUs typically run hotter than cpus but I'll agree that 80 C is hot for a CPU. My computer shuts off at 75. I wouldn't consider 30 C to be just a few degrees hotter than room temperature. That is 86 F.
    Windows 8.1 Industry Pro x64
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB x2
    Dell Poweredge T140
    8GB 2666MT/s DDR4 ECC UDIMM
    1 TB & 360 GB x2
I mean a few degrees C, not F. for example, just 4 degrees C less (26C) its a comfortable 78 F. Down 4 more degrees Celsius (now 22C) and its 72F.
    DIY
    Intel i7 920
    MSI X58 Platinum
    Corsair TX 850 watt
    Antec 900
    air
    IBM Model M
    20 mbps
I know the conversions but I thought that you where referring to F.
    8 gb
    1 TB x2
    Dell Poweredge T140
    1 TB & 360 GB x2
    LENOVO 64734VM
    15 inch
    External Speakers
The only thing about that link is its 5yrs old, so if yo have a newer chip its not it.
I thought you could just search for your cpu on the site and it would give you details.
Page link I posted could have been from my laptop
    LENOVO 64734VM
    15 inch
    External Speakers
Its misssing "i" chips
    LENOVO 64734VM
    15 inch
    External Speakers
