Solved errors shown in startup repair help!!
My desktop its an hp, having major issues and now won't boot to windows. i forgot model but i know its got wind v 32bit, intel processor, 2 512mb ram. I had did a factory image restore on 6-18-11. bout 5 days ago, it started going stupid on me. so i tried to due factory restore again. upon reboot i keep getting thrown to recovery. i try the repair my computer, and it says windows startup repair unable to repair. did chkdsk/r, looked at drive through diskpart has two patitions, both are healthy. tried again with image same results. went back to command prompt an did bootrec/fixboot, states action was completed successful. attempted image again now does a crash dump, booted back up and went to recovery and attempted safe mode, goes through drivers loading and crash dumped again. what follows is the repair detail
problem event name StartupRepairV2
prob sig 1 unknown
2 6.0.6000.16386.0.0.0.0
3 0
4 65537
5 unknown
6 NoOsinstalled
7 0
8 1
9 Fix Partition Table
10 1168
OSVersion 6.0.6000.2.0.0.256.1
Local ID: 1033
so i go through the motions and repeat repair attempt and alt prob event shows below
Problem Event Name StartupRepairV2
prob sig 1 AutoFailover
" " 2 6.0.6000.16386.6.0.6000.16386
3 6
4 196611
5 Nobootfailire
6 Failure During Setup
7 0
8 0
9 unknown
10 1168
OSVersion : 6.0.6000.2.0.0.256.1
Locale ID: 1033
these two alternate over and over, I am needing more repair info or steps I hope I still have options, thanks in advance.
    Toshiba Satellite L350D Laptop
    3 gb
    NVIDA
Have stuff you want to save?
Please, what is make and model of computer.
LOl I got it. YOu filled out specs like you were suppose to, brb.
What I found is if you
Hold down the '0' (zero) key while pressing the power button, it will open a recovery wizard that will guide you through it.
You lose your stuff and its like the day you took it home. You have to reinstall updates, SPs everything.
its a hp, pavillion forgot digits i am at the library its at home. need more specific, i can post fm my phone once i get home.
    3 gb
    NVIDA
The information I gave you is for the Toshiba, want me to find it for HP?
hold down the zero while powering on correct? is this any different from the recovery i get from the f 11 button. I have down the factory restore several times already, but I keep getting sent back, now when i try to boot it crash dumps, also when I try to get to safe mode.
    3 gb
    NVIDA
What I gave you before is for the Toshiba, follow the one above, It is the factory restoration and it should work
please, I will also apply the info you have given to my toshiba issue that I am still working on, the hp I jumped over to has stalled the toshiba work, but I think I wil have faster success with the hp because it shows the vista in all repair choices, where my toshiba doesn't list any.
    3 gb
    NVIDA
Everything has been given, above.
thank you so much richard!!!! i hope to be updating you form home this evening.
    3 gb
    NVIDA
If I dont answer, Ill get you first thing tomorrow. I do wish you luck
I followed the link you provided above, but its the same process I have been repeating and I am still receiving the above mentioned problem events.
    3 gb
    NVIDA
That means that the restore partition is corrupted and will now work.
You can go this way:
Call the computer company and get a Vista install DVD for about $25.00 (its at cost)
or the way I would go.
Get an upgrade version of Seven, for about $135.00. Be sure that your computer meets the requirments of Seven and we will help you do a clean install.
