Help choosing a CPU Cooler for overclocking
  1.    21 Oct 2011 #1
    New Zealand
    Genuine Windows 7 Home Premium x64
    Local Time: 02:40
    newzealand
    I now have a home built AMD pc which came with a Foxconn AMD Certified CPU Cooler (AKA Stock cooler).
    I overclock my Athlon II X2 255 from 3.1 to 3.8...
    Now here is the problem. The temps sit at 45c with the Stock cooler but 36c with an Aywun A10 (or something) BUT HERE ARE THE PROBLEMS:
    Stock cooler good side: quiet, small, mobo controlled fan.
    Stock cooler Bad side: Hot, small, not much to look at.
    AYWUN A-10 good side: Big to look at, keeps cpu cool
    AYWUN A-10 bad side: Under load gets loud, big (maybe restricts airflow) have to use fan controller to keep quiet.
    So my fellow overclockers which do you reccomend i use?
  2.    23 Oct 2011 #2
    US of A
    Mac OS 10.10.5
    Local Time: 09:40
    usa
    Re: Help choosing a CPU Cooler for overclocking
    45C isn't bad. I don't know about yours but my computer shuts down at 75C. Intense gaming might increase it by 10-15 degrees but you'd still be "safe" or as safe as you can be for that much overclocking. Typically the more efficient coolers are larger and can be noiser although 120 mm fans don't typically have to run as fast. Off course those are on larger heat sinks. I'm not sure how to answer your question other than to say it's personal preference.
  3.    23 Oct 2011 #3
    New Zealand
    Local Time: 02:40
    newzealand
      Thread Starter
    OK thanks, i found out its actually a A1-V4 with an 80mm fan and the heatsink size is roughly the size of the fan too. Both the fans are controlled by fan controllers. Just a question but but the aywun heatsink sits on the cpu with the fan pointing towards the drive bays... meanwhile the stock sits like normal... does this restrict airflow?
    Attached Thumbnails Attached Thumbnails -a1-v4-png
  4.    23 Oct 2011 #4
    US of A
    Mac OS 10.10.5
    Local Time: 09:40
    usa
    I don't really know a lot about heat sink design.
  5.    24 Oct 2011 #5
    Vista Home Premium x86 SP2
    Local Time: 15:40
    uk european union
    Well, I just bought a Be Quiet Dark Rock Pro: Be Quiet Dark Rock PRO BK016 CPU Cooler - Scan.co.uk
    and it is excellent! But I cannot stress just how huge it is...
    I have a big case, and it just fitted in (I couldn't slide in the motherboard tray from the rear, how to remove the motherboard tray bottom rail, slide up the tray, reinstall the bottom rail whilst holding up the tray in some precarious maneuver, and then the case side fitted on with literally half a centimetre to spare.
    But despite it being huge, and being the most evil looking cooler I have ever seen , I love it (but it sounds like an aeroplane at full power - which fortunately it rarely reaches)
    Richard
  6.    24 Oct 2011 #6
    Ultimate x64, home Prem 64
    Local Time: 10:40
    canada
    Nieriro.. that looks like a noctua nh-d14... very nice.
    Nostaw. Firstly, you can point the fan any way you want. I'd remove and turn the fan around by either switching the actual fan, or by switching the entire heatsink around. Pumping hoit air into your case is bad.
    2nd I'd switch out the fans for quality fans... Find quieter fans, though you have 80mm which trend to run faster to get the same air flow.
    I think turning your fans to exhuast out the back should be your 1st thing, as it'll cool better so you can run slower and quieter.
    Is you 45C load or idle?
anybody using a cooler master HAF932?
i just built new system over the weekend with it and gigabyte EP45-DQ6 with a Q9450. must say i am impressed with the cooling of it. only knock i...
Chillout Room
CPU Cooler
I am not overclocking my i7 but was wondering if anyone knows the best cooler that will fit with a gigabyte EX58UD4P with an i7 and in a Antec 900...
General Discussion
Best cooler for Phenom II
ok.... so whats the best cooler for the Phenom II?
General Discussion
Best Cooler for Core i7
I'm looking at OC'ing my new Core i7 920 at some point in the future. Nothing too drastic, maybe up to 3-3.2Ghz. What cooler would you guys...
General Discussion
cpu cooler
hi i want to replace the stock cooler on my amd quad core cpu but every one i keep looking at means me taking the mother board out to put a...
General Discussion
Thermalright Ultimate Cooler
If anyone has an extra TRUE cooler. I'm in the market. Just thought I'd share this info. I've decided to get a new cooler. (Or someones used TRUE)
General Discussion
CPU cooler/temps?
What CPU cooler are you using and what are your temps? I'm using a Vigor gaming 92mm Monsoon II and I've been happy with it for over a year but here...
Vista hardware & devices
Our Sites
  • Ten Forums
  • Eight Forums
  • Seven Forums
  • Help Me Bake
  • Site Links
  • Contact Us
  • Privacy and Cookies
  • About Us
    Windows Vista Forums is an independent web site and has not been authorized, sponsored, or otherwise approved by Microsoft Corporation. "Windows 10" and related materials are trademarks of Microsoft Corp.
    Designer Media Ltd
