Major Overheating Problem
  1.    20 Feb 2012 #1
    Vista Home Premium 32bit
    Local Time: 17:37
    Hi.
    I'm typing this from my desktop computer. I own a Vista with a major problem. It overheats badly. It randomly shuts down every 5-10 minutes. I know that this is due to overheating. A couple seconds after I turn the laptop on, the keys become too hot to touch. I know that loads of dust are clogging up the internals, and that the Vista needs to be cleaned out.
    Now I know what you're all thinking, "Disassemble it and use a can of compressed air, blah, blah, blah". That's where the problem comes in.
    My Vista was manufactured under the assumption that nothing bad would happen. It's impossible to disassemble. This was intentional. Unscrewing all the visible bolts under the computer does nothing. It even says this in the User's Manual. The air vents are very thin. You couldn't stick a thumbtack in there. If I can't disassemble it, then surely there is no way to clean the innards. I brought the laptop to a Best Buy store. They told me this. They informed me that there is nothing that they could do because of the design of this Vista.
    If you have some idea, please help. A week ago this problem was nonexistent. I have some really important documents saved in that Vista.
    ALSO: I have no idea why the area under my name says that. I have a 64bit Vista, not a 32.
  2.    20 Feb 2012 #2
    Central Florida in a small town
    Vista Home Basic. 32 bit SP 2
    Local Time: 16:37
    usa us florida
    Re: Major Overheating Problem
    Hello, you failed to mention make and model of the computer in question . Laptop with Vista is all i see you posted .
  3.    20 Feb 2012 #3
    Fairfield County, CT
    Windows 7 SP1 x64
    Local Time: 17:37
    usa us connecticut
    Welcome
    My advice, if you get it fixed or not. Back up now. Buy a external hard drive and back up everything with this free software
    Macrium Reflect FREE Edition - Information and download
    You should not wait until a crisis to back up. Furthermore, if it were me, I would back up now, before using the computer again.
  4.    20 Feb 2012 #4
    Ultimate x64, home Prem 64
    Local Time: 17:37
    canada
    If you can't open it, it's gonna be hard.
    I suggest usin g compressed air and a vacumm. Blow air in the out, and suck out at the in.
Major Problem
My computer is freezing about 10 seconds after being unlocked or restarted. The desktop, bottom bar and start menu all freeze but if i am able to...
Vista performance & maintenance
Major Problem, need help!
Hi, im hoping some of you technical wizards can help me on this! Right i have Vista 32bit running on my Acer, Had it about 1 year now. Every so...
Vista General
A major problem
Dear Microsoft I like Ms Outlook GUI more than WLM and tried to access my mail using Microsoft Outlook Connector (the latest Beta version...
Live Mail
Major Problem, please help
Hello All, I have got a nasty bug on my vista laptop. I have tried just about everything to clean it up but with no luck. When the bug hits, it turns...
System Security
Help need!OS problem Major
I'm running Vista Ultimate 64 bit, my computer is randomly crashing in games (Company of Heros / Crysis). The video freezes but the sound continues...
General Discussion
MAJOR Problem! Help!
Well, im on vista x64 ultimate, 4gb ram, q6600, mobo: ASUS P5N32-E Sli Plus, 8800GTX. Ok. Well im in Australia so on the 12/12/2007 i got...
General Discussion
A MAJOR PROBLEM
OK, I installed Vista and it ran perfectly for a while until one day when I ran into a driver failere during strart up. The screen said my file was...
Vista installation & setup
Our Sites
  • Ten Forums
  • Eight Forums
  • Seven Forums
  • Help Me Bake
  • Site Links
  • Contact Us
  • Privacy and Cookies
  • About Us
    Windows Vista Forums is an independent web site and has not been authorized, sponsored, or otherwise approved by Microsoft Corporation. "Windows 10" and related materials are trademarks of Microsoft Corp.
    Designer Media Ltd
