system restore problem
  1. #1
    Newbie
    Vista Home Basic 32bit
    Local Time: 11:29 AM
    I have windows vista homebasic 32 bit. My pc is not able to create System Restore Points, i tried creating it manually but it says "shadow copying of the specified volume is not supported (0x8004320C)"..
    Actually i deleted the previously created restore points by using "TuneUp Utilities" except the last one, to free up the disk space. but now i found there are no restore point available and I am not even able to create it manually.
    please suggest me some solution.!!!
  2. #2
    richc46's Avatar
    BSOD Squad
    Fairfield County, CT
    Windows 7 SP1 x64
    Local Time: 01:59 AM
    usa us connecticut
    Re: system restore problem
    Welcome
    Are you trying to store the points on the same drive that you are copying?
  3. #3
    Newbie
      Thread Starter
    yeah i just have one drive on my system and another one is recovery drive..!!
  4. #4
    Newbie
      Thread Starter
    yeah i just have only one drive on my system, another one is recovery drive...!!
  5. #5
    richc46's Avatar
    BSOD Squad
    Windows 7 SP1 x64
    usa us connecticut
    Try turning System Restore off, then boot the computer and then turn back on.
    System Restore
  6. #6
    Newbie
      Thread Starter
    i got the solution. Actually the "Microsoft software shadow copy provider" service was disabled that is why it was giving error "shadow copying not supported".
    by enabling that service, now i can create restore points manually.
  7. #7
    Cytherian's Avatar
    Senior Member
    Hoboken, NJ
    Vista Ultimate x64
    usa us new jersey
    It sounds like you're doing some aggressive tuning and maintenance on your computer. Had you previously turned off that service in one of the optimization steps to help make your computer run faster? Normally that service should be on.
  8. #8
    Newbie
      Thread Starter
    Yes may be i turned it off during tuning and maintenance of my computer.
  9. #9
    Cytherian's Avatar
    Senior Member
    Hoboken, NJ
    Vista Ultimate x64
    usa us new jersey
    OK, good to know.
    One useful thing I like to do whenever I start down one of those paths of tweaking my computer in a "new" way, is to keep a document of what I did. Open up your favorite text editor (I like Textpad), and just copy/paste the tips you've executed, in the order you did them. Also, preface this with the date so you can remember when you did this. I also like to copy/paste the links to website pages where I got them from, for future reference. This way you can look back over what you did recently when things start acting up, and see if it may be something you did that introduced the problem.
  10. #10
    Newbie
      Thread Starter
    Yeah thanks for the advice. I will follow it.
system restore problem problems?
System Restore Problem... Again JamesJ Vista General 2 17 Oct 2009
system restore Problem arsehley General Discussion 0 25 May 2009
System Restore Problem Athanasian_Creed Vista General 11 18 Apr 2008
problem with system restore Clearday Vista General 6 28 Jun 2007
System Restore Problem? Steve Vista General 0 30 Mar 2007
