Controlling the fan speed of a laptop
  1.    15 Feb 2013 #1
    Vista Home Basic 32bit
    Local Time: 22:59
    usa
    I was wondering, does anyone know how to manage a laptop's fans? I try to keep my laptop running at full speed (max power setting) and it sometimes gets quite hot, but I'm not sure if the fan is going at top speed. So, any help?
  2.    17 Feb 2013 #2
    New Zealand
    Vista Home Premium 32bit.SP2
    Local Time: 15:59
    newzealand
    Re: Controlling the fan speed of a laptop
  3.    21 Feb 2013 #3
    Local Time: 22:59
    usa
      Thread Starter
    I have it too, but I haven't figured out how to use it.
Cooling motor speed on laptop
Hi folks, my wife has a compaq presario f500 Laptop, 32-bit win 7, Could some one walk me through how to change the fan speed they have a problem...
General Discussion
controlling BitLocker
I just replaced a motherboard for a users laptop that had TPM and BitLocker active running Vista Enterprise. I recovered his BitLocker key and it...
General Discussion
Controlling display behavior on close of laptop lid
Greetings, I've recently started using a new (work) laptop that came loaded with Vista. My last laptop, which I had for about three years, was...
General Discussion
controlling winmail from vb6
If i create an email and save it to the desktop i.e. test.eml and i want to issue a command to open it from vb6 using say notepad then - Dim txtx...
Vista mail
Boost laptop harddrive speed in Vista
Nice little tweak: http://www.vistaforums.com/Forum/Topic13361-12-1.aspx Post Originated from http://www.VistaForums.com Vista Support Forums
Vista performance & maintenance
Controlling one computer from another with UI, VPN?
Hello! I want to be able to connect to my stationary computer from my laptop and be able to control it using a UI. Is this what is called VPN?...
Vista General
How to check your Speed Boost tested memory speed
Just in case anyone wants to now what the tested speed is of a device used for Ready Boost on your Vista system, it can be seen in the registry at:...
Vista General
Our Sites
  • Ten Forums
  • Eight Forums
  • Seven Forums
  • Help Me Bake
  • Site Links
  • Contact Us
  • Privacy and Cookies
  • Old server
    About Us
    Windows Vista Forums is an independent web site and has not been authorized, sponsored, or otherwise approved by Microsoft Corporation. "Windows 10" and related materials are trademarks of Microsoft Corp.
    Designer Media Ltd
