Vista 64 HP system recovery problem
Marko g
Hello & tia to All,
The installation from the recovery partition went w/o a hitch. Windows update is sluggish to non responsive. IE7 "cannot open the website-operation aborted" is the message when trying to download drivers from HP or anything from Microsoft.com. Read that I needed the current version of windows update agent and a newer version of IE but cannot get on the websites. It will open Google or AOL though.
I've recovered this laptop in the past (2+years ago) with very few problems but tonight I'm stuck. Any help or advice would be greatly appreciated.
Thanks again,
Mark
HP dv7-2043cl-vista home premium 64bit sp1
This is a good example of why Windows and other software products should be updated regularly. Microsoft ended support for SP1 in 2011. You should be running SP2 and IE9 - in fact you should be concerned that IE11 isn't supported on Vista and thinking about installing Chrome. It sounds like you're so out of date that Windows Update no longer works. Hopefully a Guru will have some suggestion other than take your PC to a repair shop.
[Edit] Sorry, after some sleep it dawns on me that I would be in the same situation if I had to recover from the factory image on my HP machine, so your question is of general interest for Vista users.
    Vista Home Premium x86 SP2
    HP Pavilion Elite m9150f
    Intel Q6600
    3 GB
    NVIDIA GeForce 8500 GT
Marko- Let me know if are you able to get to filedropper.com.
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 3200
    Logitech MX 600
    30 Mbps
No problem Vistaar, I took your advice and dropped them both at a local shop. Yea I said both, my mother's and wife's. Boneheaded move trying to do both. Hopefully I'll get solid reinstalls from this guy, can hardly wait to get out of the "double dog house".
Let us know how it turns out.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 3200
    Logitech MX 600
    30 Mbps
