Solved Current Vista Home Premium Users: Are these running on your system?
AndyTampa
I'm trying to find out if Group Policy is normally running on a Vista Home Premium system. While there are plenty of helpful people on the forum, most of them are running new versions of Windows. They can't tell me if these items are on a Vista system simply because they are not running it.
Vista Home Premium does not have a group policy manager installed. It is mainly for business versions like Enterprise and Professional. Could you please search your registry for "Group Policy" and tell me if you find any Group Policy entries (don't change anything in your registry) or if gpsvc (Group Policy Client) is running in your Task Manager Services tab?
    Windows Vista Home Premium SP2, 32-bit
    Retrofitted Refurbished Gateway
    AMD
    ASUS M3A78-EM
    Acer 22-in Flat Screen Monitor
    Logitech K350 Wireless Keyboard
    Logitech M705 Wireless Mouse
Yes, if I run regedit > Edit > Find > "group policy" I get some results; and yes, gpsvc is running.
I reinstalled Vista about a month ago (something you should probably consider). As far as I know, the only thing I have done since then that would involve Group Policy was run a Microsoft Fix-it to disable Windows Side Bar.
    Vista Home Premium x86 SP2
    HP Pavilion Elite m9150f
    Intel Q6600
    3 GB
    NVIDIA GeForce 8500 GT
Thank you Vistaar. Through looking at the registry entries, they appear to reference Group Policy programs installed in the System32 folder. The think missing from Home Premium appears to only be the User Interface. I did find a couple of other programs also used Group Policy in their settings.
I consider my quest for answers resolved.
    AMD
    ASUS M3A78-EM
I think that the only application of Group Policy in Vista is in regards to User Access Controls. That is, whether or not a user is a standard user or an administrator, the available permissions vary.
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 3200
    Logitech MX 600
    30 Mbps
