Go Back   Vista Forums > Vista Forums > Graphic cards
Vista - need help connecting my TV to my PC
Old 10-29-2007   #1 (permalink)
Vista 32bit
i got HDMI cabel.
for some reason, the TV says that there is no signal.
after installing something, i needed to reboot me pc, and while the boot was loaded, there was a signal, and i could see the pic in the tv.
at that time my pc monitor turned of automaticly.
when windows was opend, the TV shows again that there's no signal, and the pc monitor turned on..
so its the settings..
i have windows vista x32, and my graphics card is GForce FX-8600 512MB.
I need your help..
Old 10-30-2007   #2 (permalink)
Vista Home Premium 64-bit
Re: need help connecting my TV to my PC
are you using an adapter or direct hdmi from the card?
try disconnecting the monitor with the power off, then boot it up and see if it stays on the tv
Old 11-01-2007   #3 (permalink)
Vista 32bit
Quote  Quote: Originally Posted by phazed View Post
the bacle is connected to the card, no adaptors..
mm i tried what you told me, but it didn't work.
OT ? - How am I connecting Vista General
Connecting to a VPN Vista General
Connecting to a VPN Vista networking & sharing
connecting to tv Vista General
connecting pda Vista General
