Go Back   Vista Forums > Vista Forums > Graphic cards
Vista - Vista resolution problem, please help.
Old 07-28-2008   #11 (permalink)
Ultimate SP1 x64 & x86
Re: Vista resolution problem, please help.
Quote  Quote: Originally Posted by sabcully View Post
Hi
I have only installed the drivers that came with the card and downloaded the lates from the navidia website. Sorry to be vague but am totally out of my depth with this as never had to deal with this.
My monitor is a CHIMEI CMV223D.
Desktop, 4 Quad Q9300, 8192 Corsair DDR2.
Thanx for all your help.
Have a look in devices manager if your monotor is recognize as CHIMEI or plug and play.
Old 07-29-2008   #12 (permalink)
Vista Ultimate x64
Thanx KyColonelT
This is going to cause me a problem cos I had stuff done to the computer to get my internet sorted out at last and restoring will undo that too.
Not sure what to do about that.
HP, should have known.
Ta again.
Old 07-29-2008   #13 (permalink)
Vista Ultimate x64
Sid,
I can't find my monitor at all in device manager.
Old 07-29-2008   #14 (permalink)
Sabcully,
Can you check in the Nvidia manager and update the monitor drivers if only plug and play is shown.
Old 07-30-2008   #15 (permalink)
Vista Ultimate x64
Hi everybody,
you would not believe it. Been hunting around for the solution for days now. Have come across this in all sorts of places, people think its the monitor, CHIMEI, others think it is vista and others the nvidia software. Probably a bit of all.
THE SOLUTION:
Install the latest driver for card, switch off computer, unplug DVI cable and power from monitor, wait a few minutes, switch computer back on and: Your monitor and graphics card is working fine together.
This has worked for a lot of people and for me too. Such a frustrating problem with such an easy answer. Hope it will keep working. My monitor has turned up in the device manager again as well now.
Thanx for all your help!
Old 07-30-2008   #16 (permalink)
Glad it works!
But (i always say there is a but) maybe the problem will come back.
Is the monitor recognized as Chimei or plug an play?
Old 07-30-2008   #17 (permalink)
Vista Ultimate x64
Only plug and play.
Old 07-30-2008   #18 (permalink)
Well, that is what i thought and maybe your problem came from the monitor.
Now it is recognized, update the monitor drivers with the drivers which came with it.
Old 07-30-2008   #19 (permalink)
Vista Ultimate x64
Sid,
been looking for Chimei drivers but have not been able to find any. Have found out though that the 'no signal' problem is not exclusive to CHIMEI monitors.
Will have another go.
Thanx a lot. :-)
Old 09-01-2008   #20 (permalink)
Vista Home Premium 32bit
i have the same prob
another vista resolution problem Graphic cards
Odd monitor resolution problem..Vista strikes again Vista General
Vista name resolution problem Vista networking & sharing
VISTA & 1440x900 Resolution Problem General Discussion
Vista Resolution Problem Vista hardware & devices
