help me for VGA
  1. #11
    Vista Ultimate 64 bit
    Local Time: 05:53 PM
    bahrain
      Thread Starter
    Re: help me for VGA
    Do you have been in vain tried my Climate VGA screen??
  2. #12
    johngalt's Avatar
    Antidisestablishmentarian
    3rd Rock
    Windows 7 Ultimate x64
    Local Time: 07:53 PM
    usa us georgia
    Re: help me for VGA
    No offense, but that post makes very little sense - I suspect you are not an English speaking person, and there is nothing wrong with that - but the translation may make perfect sense to you but it does not here.
  3. #13
    bahrain
      Thread Starter
    Re: help me for VGA
    Change VGA on mycomputer ??
  4. #14
    Dwarf's Avatar
    The Contemplator
    Doncaster, UK
    Windows Vista Ultimate x64 Service Pack 2
    Local Time: 12:53 AM
    england uk yorkshire
    Re: help me for VGA
    Hi Jrak,
    Your graphics card supports the native resolution of your display, and I would leave that as it is. A TFT/LCD display always works best and gives the clearest image when it is working at its native resolution. You may like to see if changing any settings in the 'Ease of Access Center' helps. Click on the start orb, type 'Ease of Access Center' into the search box and press enter/return. Click on 'Make the computer easier to see' and try the available settings. You will have to experiment a bit to find a combination of adjustments that suits you.
    Dwarf
  5. #15
    bahrain
      Thread Starter
    Re: help me for VGA
    Thank you
Page 2 of 2 FirstFirst 12
help me for VGA problems?
