Go Back   Vista Forums > Vista Forums > Graphic cards
Vista - 6800GT problems
Old 08-14-2008   #1 (permalink)
Vista Ultimate x64
6800GT problems
i just upgraded my system, but kept my graphics card (q9300, 4gb ram, X48 mobo). and now games run a 1-2 fps. but sometimes if i roll back to the original wddm driver, games will work. HL2 works all the time, but Live for Speed, Crysis, FEAR, and BF2 all play up. But then sometimes they just work. Anyone else had problems like this?
This also effects video playback (avi, mpeg....)
Old 08-14-2008   #2 (permalink)
Win XP Pro / Win Vista Ultimate
Re: 6800GT problems
do you have the latest video card driver installed? (version 175.19 on nvidia.com)
check for overheating using HWmonitor.
Old 08-14-2008   #3 (permalink)
Vista Ultimate x64
Re: 6800GT problems
you need a new GFX card, that old thing is bottlenecking the Q9300.. badly.
get a Cheap 8800GT now on sale for $119.00 on Newegg.com
Old 08-14-2008   #4 (permalink)
Vista Ultimate x64
Re: 6800GT problems
the latest drivers were the first i tried, and i've tried some other versions. still the same problem. I'll check for overheating, but i doubt it's that
i know the 6800GT is old, but I don't have the $$ for a better one at the moment
Old 08-15-2008   #5 (permalink)
Vista HP 64
Re: 6800GT problems
Found this thread while I've been googling to try and find a solution to the exact same problem. I upgraded to an Abit ip35 pro and C2D 3.16Ghz.
I have problems with stuttering xvid videos in 32 bit media player and unplayable frame rates in any games I've tried.
64 bit media player works just great. It's almost as if the hardware acceleration isn't working when running 32bit programs.
Old 08-15-2008   #6 (permalink)
Vista Ultimate x64
Re: 6800GT problems
i just tried WMP64 and my videos work fine, probably explains why HL2 works, as it's got a 64bit mode.
I'll have to try Crysis in 64bit mode and see if it works.
Old 08-15-2008   #7 (permalink)
Vista Ultimate x64
Re: 6800GT problems
there is still a problem tho. as I can use both 32 and 64bit modes. but I do have a GTX260 tho so that might be a factor..
Old 08-17-2008   #8 (permalink)
Vista Ultimate x64
Re: 6800GT problems
I tested Crysis 64 bit, and it worked like a dream. seems a really weird problem that only 64 apps get hardware acceleration. Now to find a fix.
Old 08-17-2008   #9 (permalink)
Vista HP 64
Re: 6800GT problems
Quote  Quote: Originally Posted by savman View Post
A quick thought as I've been googling here at work tonight and I seem to have come across some people claiming to have issues with getting the fan to 'kick in' and cool when the card was under load.
That might go some way to explaining things as my card is always ok for the first 3-4 minutes before I'd get the problems I mentioned above, maybe there is some program/tool you can use to keep the fan running?
Just a thought anyways, let me know if you have any luck, I have a feeling I'm going to end up biting the bullet and buying a 4850 anyways....
Old 08-17-2008   #10 (permalink)
Vista Ultimate x64
Re: 6800GT problems
When mine plays up, it buggers up from the moment the game loads. even the nvida the way is's ment to be played bull**** goes 1-2 fps
6800GT/Vista64/6gb RAM issue Gaming
Problems starting command prompt on cygwin on vista ultimate, problems not had on Win2k3SP2 Vista General
Any success with 6800GT Vista hardware & devices
nVidia 6800GT...Blank screen after changing resolution Vista hardware & devices
Nvidia GeForce 6800GT working very hard. Vista performance & maintenance
