Go Back   Vista Forums > Vista Forums > Graphic cards
Vista - need help with my graphic card
Old 10-04-2008   #1 (permalink)
windows vista business (6.0, build 6001)
i have a mobile intel (r)965 express chipset family graphic card/driver. is it possible to upgrade to nvidia? can any1 help me update my graphic card to nvidia step by step?
Old 10-04-2008   #2 (permalink)
Vista Ultimate 64bit SP2/
Re: need help with my graphic card
Need your laptop make and model.
Old 10-04-2008   #3 (permalink)
its toshiba satellite a200
Old 10-04-2008   #4 (permalink)
I believe that you can't upgrade the graphics because its part of the motherboard.
Old 10-04-2008   #5 (permalink)
is their anyway i can upgrade to nvidia? can i upgrade the motherboard?
Old 10-05-2008   #6 (permalink)
Vista Ultimate x64
not on a laptop as they are built around the motherboard if you did try to change it then the cpu fan might be in the wrong place the harddrive might not mount in it's slot and the dvd drive would probably not be able to attach to the mobo the only way would be to buy a new laptop with an nvidia card.
Graphic Card ? Graphic cards
Graphic card Virtual PC
Video card? Graphic card? Vista General
The best graphic card Graphic cards
Graphic Card Vista General
