Go Back   Vista Forums > Vista Forums > Graphic cards
Vista - Help on my vga card
Old 10-14-2008   #1 (permalink)
vista ultimate
Help on my vga card
My Standard Vga Graphics Adapter is not detected on my laptop how can i change it???
Old 10-14-2008   #2 (permalink)
Vista Ultimate 32bit
Re: Help on my vga card
Try going into BIOS and check out the settings. I don't know what type of machine/laptop you are using or what type of graphics card you are running but checking out the Bios is a sure way to find out what you machine is set to.
Hope this helps?
P.S. To enter Bios is not the same on every machine could be holding down the Ctrl key and constantly hitting the Del key will let you in but there are quite a few F12, F2 and so on. Look at your post screen as it will tell you how you can enter Bios on your machine.
Old 10-15-2008   #3 (permalink)
vista ultimate
my machine/laptop is Sharp-Pc-AL70J when i press ctrl key and then press del it not works and also when i hit f12 or f2 nothing works i dnt have any vga carp its only a standard video card but when i view the standard vga card it said that its not detected but its already installed
Old 10-15-2008   #4 (permalink)
Vista Ultimate x64
get in touch with the supplier for support and call the manufacturer or send it back to the manufacturer for this, a collegue of mine had a similar problem and thay ended up replacing the laptop as it was a hardware failure, on laptops the parts can't be replaced (usually). pc's are easier to problem solve as parts can be replaced with ease laptops however are not designed that way.
assuming it's a new laptop and still under warranty call them and go through it with them, they will either solve or send you a new one under the conditions of the warranty.
Old 10-16-2008   #5 (permalink)
vista ultimate
sorry cause my laptop is old this is a gift for my aunt.. ^^
Flash Memory Card Reader - 16 GB SD Card - Won't Read Vista hardware & devices
Installing a PCMCIA Card Drive in desktop to use PC5740 card in Vista networking & sharing
Vista does not boot if I add the WinTV card (or the PCTV Card) Vista hardware & devices
nw8000 internal SD card reader handles every card as read-only Vista hardware & devices
Nforce 430, onboard sound card and video card issues Vista hardware & devices
