Go Back   Vista Forums > Vista Forums > Graphic cards
Vista - Resolution problem
Old 11-07-2008   #1 (permalink)
Vista Home Premium x64
Resolution problem
I got a problem with my resolution, I cant choose higher than 1024x768.
I have uninstalled/reinstalled, cleaned all drivers both for my screen and video card, nothing works. When I have uninstalled my grapich card i can choose higher res, but when I reinstall it, it will set back to 1024x768.
I have looked all over but cant find anyone with the same problem, please help me!
Thank you in advance!
/MrWIB
********************** Computer Info ************************
Computer Model: System Product Name
Computer Manufacturer: System manufacturer
OS Name: Microsoft® Windows Vista™ Home Premium |C:\Windows|\Device\Harddisk0\Partition1
OS Version: 6.0.6001
System Type: x64-based PC
Total Physical Memory: 4094 MB
Windows Directory: C:\Windows
BIOS Version: BIOS Date: 07/04/08 15:40:39 Ver: 04.01
CPU: AMD Athlon(tm) 64 X2 Dual Core Processor 6000+
Video Card: NVIDIA GeForce 9500 GT
Resolution: 1024 x 768 x 4294967296 colors
************************ Video Card *************************
Brand: NVIDIA
Model: NVIDIA GeForce 9500 GT
Adapter DAC Type: Integrated RAMDAC
Adapter RAM: 256 MB
Current BitsPerPixel: 32
Current Number Of Colors: 4294967296
Current Refresh Rate: 60
Driver Date: 10/23/2008 06:42:00
Driver Version: 7.15.11.8043
MaxRefreshRate: 75
MinRefreshRate: 56
Status: OK
Video Memory Type: 2
Video Mode Description: 1024 x 768 x 4294967296 colors
Video Processor: GeForce 9500 GT
Old 11-07-2008   #2 (permalink)
Vista Ultimate x64
Re: Resolution problem
Welcome to the forum!
Where did you get those drivers? There are new ones available at the nvidia website, here's a link: GeForce Release 178
Amplid
Old 11-08-2008   #3 (permalink)
Quote  Quote: Originally Posted by amplid View Post
Thx
Yes I have tried all the latest drivers, incl beta versions. It still wont work...
/MrWIB
Old 11-08-2008   #4 (permalink)
Vista Ultimate x64
Do you have driver for your screen as well (the latest one...)? That might help.
Amplid
Old 11-08-2008   #5 (permalink)
Yes, I have installed new drivers for all hardware that I can think of (after that I tried with the old ones).
Im very confused...
/MrWIB
Old 11-08-2008   #6 (permalink)
I have not used Windows update, I have downloaded the drivers from Nvidia and the other manufacturers.
/MrWIB
Old 11-08-2008   #7 (permalink)
Vista Ultimate x64
Did you always have this problem, or did it occur after (un)installing new software, drivers, hardware,...?
Amplid
Old 11-08-2008   #8 (permalink)
Its a brand new computer, that I built myself (so I never had this problem). It just didnt "work" when I started it. Everything else is running fine...
/MrWIB
Old 11-08-2008   #9 (permalink)
Vista Ultimate x64
If, on your desktop, you do right-click > personalization > Display setting. What does it say? Do you have a default monitor and the brand monitor?
Like this:
Amplid
Old 11-08-2008   #10 (permalink)
I can choose from these 2 (see attached), the SyncMaster is set as "standard".
Edit: Sorry for the swedish text
Resolution problem Drivers
Name resolution problem Network & Sharing
Resolution problem Vista performance & maintenance
Resolution problem Vista General
