Go Back   Vista Forums > Vista Forums > Graphic cards
Vista - driver problem ?
Old 11-25-2008   #1 (permalink)
business x64
driver problem ?
I recieve the folowing error when trying to play any game or use google earth: "Display driver atikmdag stopped responding and has successfully recovered". I have vista ultimate 32bit, two monitors powerder by ultramon and radeon x1550 graphic card(newest drivers installed).
Has anyone the similar problem ? Has anyone idea where is the problem ?
Old 11-25-2008   #2 (permalink)
vista ultimate 64 x 32
Re: driver problem ?
hi i have had similar problem when using 2 monitors in 64 bit from what i could find out it has to do with using 2 monitors i gave up on my ati card and bought an nvidia 9500 no more problems
Old 11-25-2008   #3 (permalink)
business x64
i tried to shut down the second monitor in display settings. The same problem occures in tray
Old 11-25-2008   #4 (permalink)
the only permanent fix i found was to remove the second monitor
i did get it reasonably stable by uninstalling all ati software and then go to device manager and install the drivers for the card there and not use the ati installer
Old 01-18-2009   #5 (permalink)
Vista Ultimate 64
Quote  Quote: Originally Posted by chinga69 View Post
Hi chinga69
Are you still having sucess with the nvidia? I have the same ati issue with 2 monitors, and am looking for options.
Old 01-18-2009   #6 (permalink)
Vista x64 + Windows 7 x64 (Ultimate)
Have you guys checked your Device Manager to see if both your monitors are there and not just the Generic PnP & Non-Pnp monitors? the answer might be as simple as updating your monitors drivers for x64 profiles.
Old 01-18-2009   #7 (permalink)
Quote  Quote: Originally Posted by Litewave View Post
Hi chinga69
yes i have not had that issue since changing to nvidia
cheers brad
Old 01-19-2009   #8 (permalink)
Vista Ultimate 64
Hi chinga69
cheers brad
Thats great news. Im still trying to stabilize my system. Have done the same, removed ATI, CCC etc.. and now using nvidia.
It's a 2 week old build, it's getting better !
Thanks for your assistance
Old 01-19-2009   #9 (permalink)
Vista Ultimate 64
Quote  Quote: Originally Posted by AstaLaVista View Post
Sorry for the delay in responding to your reply. I did check the Westinghouse site for drivers for my 2 lcd's, there are none there
Thanks for your response.
I have problem starting up Vista - problem with driver Drivers
for user that have the driver problem driver. How do we clean inst Vista installation & setup
Another problem with CD/DVD driver Vista hardware & devices
RE: Vista install problem - Failed to add driver package into driver s Vista installation & setup
WLMd crashing problem, possible problem with Vid. Driver?? Vista General
