Go Back   Vista Forums > Vista Forums > Graphic cards
Vista - Second Monitor Help
Old 12-22-2008   #1 (permalink)
Vista Ultimate x64
Second Monitor Help
Hey,
I have my TV connected as the second output on my graphics card but Windows only recognises it if I boot up the PC with the TV selected to "HDMI2" (what the PC's connected to.)
So, every time I go to use TV as the second screen I have to put it on to HDMI2, go into Display Settings, select the second screen and click "extend the desktop to this monitor" etc.
Is there a script or something I can run which will do all of that, so all I have to do is run the script?
Old 12-23-2008   #2 (permalink)
Vista Home Premium x64
Re: Second Monitor Help
if you set the correct settings in the Nvidia control panel your system should retain your settings for future use.
Solved keep monitor on General Discussion
HELP! Monitor Settings Issues: Can't Alter the Monitor Settings... Vista hardware & devices
Closing notebook monitor switches desktop to connected 2nd monitor Vista General
4 screens on one monitor and monitor won't wake up from sleep mode Vista hardware & devices
Monitor or Monitor Driver? Vista hardware & devices
