Go Back   Vista Forums > Vista Forums > Graphic cards
Vista - Extnded 4 monitor problem
Old 02-01-2009   #1 (permalink)
Vista business 32bit
Hi, I have a problem with my pc.
The onboard adapter is an ATI Radeon x1250 and the second adapter is an ATI HD2400. When I connect 4 monitor, everytime I shut down or restart my pc I loose all my settings. The second monitor is always disabled and put at the left side of my primary monitor. I installed catalyst 9.1 drvers and the pc is a Lenovo Thinkcentre A61 9143-CTO.
Have you got any suggestion,please?
Thank you in advanced for your help.
Massimo
Old 02-01-2009   #2 (permalink)
Windows 7 x64 build 7100 & Ubuntu 9.04
Re: Extnded 4 monitor problem
Hello micm74 and welcome.
Pretty cool setup with 4 monitors.
As for the problem, it may be cause by having two different video cards installed in your PC.
~Lordbob
Old 02-01-2009   #3 (permalink)
Vista Ultimate x64
May or may not work but give the free trial of Ultramon a try,
Realtime Soft UltraMon
Old 02-02-2009   #4 (permalink)
Hi, when I baught my desktop I asked for a pc with 4 monitors and IBM found this solution. I really don't think it's a problem of the adapters.
I can set all my monitors, I work with them. It's enough a restart or a shut down and all my settings are loose. I find all my icons but in the wrong position.
Thank you for all.
Old 02-02-2009   #5 (permalink)
Windows 7 Ultimate x64
Have you tried different drivers?
I've never had any problems like this running my 4 monitors.
Old 02-02-2009   #6 (permalink)
What do you mean its not a problem with adapters? I still think that it could be a problem with runnin two different Video cards...
~Lordbob
Old 02-03-2009   #7 (permalink)
I mean that IBM sold me this pc and I don't think they sold me a pc not tested for 4 monitor. I ask them for a pc with 4 monitor. I believe....
I try a lot of different drivers but same problem.
What do you mean about permission on the registry?
Solved Dual monitor problem Graphic cards
Problem with KVM as second monitor Vista General
Dual Monitor Problem Vista hardware & devices
Another Monitor Problem Vista hardware & devices
monitor problem Vista hardware & devices
