| vista home premium 32bit | Help problem This message appeared today: ATI WARNING The Catalyst Control Centre is not suppored by the driver version of your enabled graphics adapter. Please update you ATI graphic driver, or enable your ATI adapter using the Displays Manager. But the thing is I dont know how to do this or what to do can someone help!!!! |
| Vista Home Premium 32bit and Ubuntu 9.10 32bit | Re: Help problem get the ccc from amd and install the newest version and see if that works |
| Vista Ultimate 32bit | Re: Help problem Go to the ATI Website and according to the model of the graphic card download and install the latest Version of the Driver - |
| Windows 7 x64 build 7100 & Ubuntu 9.04 | Re: Help problem Hey PizzaMan you got Power! Nice. Hello to seebyher as well. As said above, update your drivers. Pick them out from the ATI Drivers here. ~Lordbob |
| Vista Home Premium x64 | Re: Help problem Don't use the CD that came with the system or card. Download these from the correct video card....ATI...Sapphire... etc website. Keep in mind that the current version is 8.12 and there are differences between the overclocking features on the CCC. The 4870x2 has the ability for setting the fan speed while the other CCC's seam to not show this, just in case you are wishng to use that tool. They will also show the lower section as 300 but when the card is in use the actual default changes to higher. Riva does show this. |
| the problem with ndis.sys Blue Screen of Death problem solved? | Vista General | |||
| Re: Windows Mail Attachement Problem and Adobe Player Problem with IE8 | Vista mail | |||
| Multi-select problem in Windows Explorer BIG PROBLEM!!!!!! | Vista General | |||
| Generic McAfee Problem Message in Vista Problem Reports | Vista performance & maintenance | |||
| Vista Upgrade Problem - Windows Explorer Loop problem | Vista installation & setup | |||
