Solved Dedicated system memory for graphics card
brummyfan
Brummy
Hi
I am upgrading the memory to 2GB from 1GB, could someone please tell me whether I can change the Dedicated system memory from 64MB to 128 MB or just leave it as it is. I have attached the current info.
    Biostar
    Biostar MCP6P-M2
    NVIDIA GeForce 8400GS
    CIBOX
    Hitachi 160GB
Hello Brummy,
Since it appears to be a integrated graphics chip, then you may be able to adjust how much dedicated system memory you want to use in BIOS for it.
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
Hi brummyfan,
I don't think that you can change this (unless the option is there in your BIOS - check the manual).
Dedicated graphics memory refers to memory that is included on a graphics card, whereas Dedicated system memory refers to memory that is assigned to an onboard graphics solution.
The Total available graphics memory is made up of Shared system memory and either of the above, depending upon whether you are using built-in graphics or a graphics card.
When you increase your main system memory, it is possible that the amount of Shared system memory will increase, but that depends on the system architecture and options available in your BIOS.
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Iomega 1.5TB Ext USB 2.0
    WD 2.0TB Ext USB 3.0
    Gigabyte IF233
Thank you guys, your detailed information much appreciated.
    Biostar
    Biostar MCP6P-M2
    CIBOX
    Hitachi 160GB
You're welcome Brummy. :)
