Go Back   Vista Forums > Vista Forums > Graphic cards
Vista - display resolution problem
Old 02-21-2009   #1 (permalink)
Vista Home Premium 64bit
Hi Friends,
For past one year,I am using hp pavilion notebook dv6700 with following configuration
Intel Core2Duo 2.1 Gh
4MB RAM,250GB Hard disk
Nvidia GeForce 8400M GS 256 MB graphics card(latest updated driver as on 21.02.09)
Windows Vista Home Premium 64 bit with SP1 integrated
About three weeks back I uninstalled Microsoft office 2007 and after that I noticed that although the resolution of my laptop display is adjusted to maximum at 1280X800 but the icons appear a little blur at their edges and the messages boxes that open do not show all the matter and commands that are there (screenshot attached).
I have scanned my window’s registry and also I have checked all the files with scannow option but nothing was found wrong anywhere and also all the drivers are working properly. But I cannot change the resolution by any means and my problem remains the same.
Can anyone help me out please?
Thanx in advance.
Old 02-21-2009   #2 (permalink)
Vista Home Premium x64
Re: display resolution problem
Quote  Quote: Originally Posted by novice1 View Post
Hi Friends,
Thanx in advance.
your resolution is correct, your DPI settings are not.
right click your desktop anywhere, click on personalization, on the left of that window should be an option saying adjust font size (DPI), in that new window, your font size, if im correct should be set at 120 DPI, set it to 96 DPI and restart, this should fix the issue
Old 02-22-2009   #3 (permalink)
Thanks MrNeeds for lending me a helping hand,but DPI of my notebook is already set to 96 only (screenshot attached)
Old 02-22-2009   #4 (permalink)
ok, can you change your resolution to a lower one, something like 1024x768, then change it back to the default resolution? sometimes that can have an effect on dpi scale.
edit: nvm just read first post again, ok, ive just had a brainwave, can you change your theme? change it to vista basic, looks like you may have a much larger font than windows can display properly.
Old 03-10-2009   #5 (permalink)
Vista Home Basic 32bit.
Display resolution problem
Hi Friends ,
I recently bought compaq presario, It has the 32 bit windows visa home basic.
Screen resolution looks good. But when I open any webpage, the pictures look blurr. Please help. I'm so pissed off with this problem.
I open orkut and can see only few blurr images. Help!!!!!!!!!!!!!
Thanks,
Prachi
Old 03-11-2009   #6 (permalink)
Dual booting xp and vista x32
Hello, first post here on vista forums
I used to have windows vista home basic, and I recently upgraded to Ultimate
I have an hp 530 notebook,
the specs are as follows:
Integrated graphics
2gig RAM
120 hard drive
1.6 celeron
For some reason when I upgraded to Ultimate everything was really visually unnappealing and it wasn't even letting me use certain screensavers
so, I checked the status of my graphics card and it says that it is unable to start...
would anyone here know a solution to my problem?
also, I have 256 vram and support for directx9 that should be enough to run aero right?
*edit nvm reinstalled graphics driver and everything works great--even aero!*
Display resolution changes spontaneously Vista General
Display resolution not the same as before Graphic cards
big display problem; can't get native resolution anymore! Graphic cards
Cannot reduce display resolution Vista General
Can't change my display resolution Vista General
