Go Back   Vista Forums > Vista Forums > Graphic cards
Vista - Tv as monitor help please!
Old 04-03-2009   #1 (permalink)
Vista home premium 32bit
Hello all I am having quite the troubles with using my tv as a monitor my tv is an High def 27 inch RCA tv, It has a VGA port on it and considering my cable that im using is male going into the female output on the graphics card and being male on the other end I had bought a DVI female to VGA male so that I could possibly get it to work.
I put the attatchment I bought into the VGA port on my tv and plugged the male DVI into the female DVI and I switched my input to PC but I get no signal,
Any ideas?
Old 04-03-2009   #2 (permalink)
Vista Ultimate X32
Re: Tv as monitor help please!
You may need to reboot your PC to detect the tv while the tv was on and conencted.
What model video card are you using?
I know with my Nvidia card, because of a component switch box I am using, I have to change the resolution of my TV a couple times in the Display properties before it will display on my tv.
Is your TV even being detected by the video card? If not, you may not have it on the correct channel or TV input selection on the TV itself. Mine has 3, PC is TV2 I think.
Also, Are you Cloning the image to the TV or independant?
Old 04-03-2009   #3 (permalink)
Quote  Quote: Originally Posted by Tepid View Post
I have a GeForce 8800GS
And I had restarted my PC and still said no signal
I have not tried fiddling around with the resolution yet,
Old 04-04-2009   #4 (permalink)
Quote  Quote: Originally Posted by kenjiemichael View Post
hands off I think you have to set it also in your video card setting.
refresh rates is also an issue i guess. try to lowering it for start.
what must I change in the nvidia panel?
Old 04-06-2009   #5 (permalink)
Windows 7 Ultimate 32Bit (Build 7600)
Quote  Quote: Originally Posted by KOSSwifty View Post
Under Display>Change Resolution, make sure that you set the refresh rate to no more than 30 Hertz.
Is your TV identified within the control panel?
Also as Tepid stated earlier are you selecting the correct input on your TV remote?
Old 04-06-2009   #6 (permalink)
Vista Home Premium 32-bit & Vista Ultimate 64-bit both Service Pack 2 W7 Pro RTM 7600 32 & 64
What is the exact make and model number of the TV/monitor?
Old 04-06-2009   #7 (permalink)
Vista x64 + Windows 7 x64 (Ultimate)
I am also having a similar issue and I have not being able to get it to work with Vista x64. I know I did it before under XP and this is what I did.
Go to your Nvidia Control Panel and look for "Setting up dual Monitors", you should be able to see your Primary Monitor and the 2nd monitor (your TV in this case).
If that doesn't work, go to:
your desktop, right click and hit "Personalize", once this window is open get to your Display settings and Make sure you can see the 2nd monitor and make it your primary.
Now, be advise that once you do this, you no longer have access to your primary monitor so all moves with mouse and keyboard must be done by your TV as a monitor and it may be a bit complex if the resolutions are to the extreme. what I mean by this is that my old TV is 480i and my 22" LCD is set at 1680 x 1050 so for me to navigate around my TV is extremely painful (but doable).
Again, I know there should be a correct way to do this and I haven't been able to discover it with Vista and with XP that was just a work-around way to do it.
Hopefully, someone with more knowledge will chime in.
Old 04-06-2009   #8 (permalink)
Quote  Quote: Originally Posted by AstaLaVista View Post
I am aware that some TV/Video card combinations do not like multiple monitors. It is worth trying this with only the TV attached.
Old 04-06-2009   #9 (permalink)
Quote  Quote: Originally Posted by UKMedia View Post
Sorry, I guess I forgot to add that I am doing this with the Color Stream (component cables Red/Green/Blue cables) and not direct with VGA/DVI or HDMI cables so I don't believe this is doable for me, perhaps for the Original Poster it will
Old 04-06-2009   #10 (permalink)
I have used S-Video instead and I got to set it up but the visuals were so horribal I had to switch back to my regular monitor,
Im guessing I must obtain a HDMI to DVI and then set it up from my Computer monitor and then use my tv as primary and then take down my computer monitor is that correct?
Solved keep monitor on General Discussion
HELP! Monitor Settings Issues: Can't Alter the Monitor Settings... Vista hardware & devices
Closing notebook monitor switches desktop to connected 2nd monitor Vista General
4 screens on one monitor and monitor won't wake up from sleep mode Vista hardware & devices
Monitor or Monitor Driver? Vista hardware & devices
