| Vista Home Premium 64bit | monitor not working with vga ive just unplugged all my pc cos i was having new floors put down , and when ive just set it up again the moniters not working. The pc is booting up fine but the screen says no signal then just goes black, i had the same problem when a pc repair guy came round and used the pc moniter to connect my laptop, and when he put the vga cable back in the pc tower it was doing the same as now, but he just did summit and got it working anyone got any ideas whats going wrong? |
| vista home premium 64 | re: monitor not working with vga I had a monitor that did that, turned out to be one of the pins in VGA connector was pushed back into the casing. I bodged it up by pulling the pin back with pliers, but changed the cable in the end. I have also seen a monitor with one of the pins bent around and against the metal case, that was also carefully straightened, and worked fine. Of course your monitor problem may not be anything to do with the above :-( Barry |
| Vista Home Premium 64bit | re: monitor not working with vga I had a monitor that did that, turned out to be one of the pins in VGA connector was pushed back into the casing. I bodged it up by pulling the pin back with pliers, but changed the cable in the end. I have also seen a monitor with one of the pins bent around and against the metal case, that was also carefully straightened, and worked fine. Of course your monitor problem may not be anything to do with the above :-( Barry |
| Vista Home Premium 64 bit | re: monitor not working with vga I think you have to go into the monitors menu and set it up for digital input or analog input. |
| Vista Home Premium 32-bit & Vista Ultimate 64-bit both Service Pack 2 W7 Pro RTM 7600 32 & 64 | re: monitor not working with vga I agree with Barry in that your best option would be to replace the monitor cable, especially as you have had this problem with it before. Just because the pins on the connectors are OK it doesn't mean to say that the wiring in the cable itself is. One or more of the wires may have a break somewhere which can cause this problem, especially if the cable is tightly folded and bound for the sake of cable management. |
| | #6 (permalink) |
| Vista Home Premium 64bit | re: monitor not working with vga im not to familiar with the vga cables because its not my computer .i use hdmi for mine and i was just wondering once the vga is connected both sides should it usually show on the moniter just without audio ?unlike HDMIill try again tomoz see if it works ,if not just buy one but its only about year old the pc and the vga cable has only been unplugged twice |
| | #7 (permalink) |
| Vista Home Premium 64 bit | re: monitor not working with vga Does this monitor support both HDMI and analog? If so, I believe you need to set that up in the monitor menu were you also set contract and brightness etc. |
| | #8 (permalink) |
| Vista Home Premium 64bit | re: monitor not working with vga |
| | #9 (permalink) |
| Vista Home Premium 64 bit | re: monitor not working with vga Just a thought...perhaps the bulb in the monitor has blown out! |
| | #10 (permalink) |
| Vista Home Premium x64 | re: monitor not working with vga )ive just unplugged all my pc cos i was having new floors put down , and when ive just set it up again the moniters not working. The pc is booting up fine but the screen says no signal then just goes black, i had the same problem when a pc repair guy came round and used the pc moniter to connect my laptop, and when he put the vga cable back in the pc tower it was doing the same as now, but he just did summit and got it working anyone got any ideas whats going wrong? |
| Digital DVI Monitor not Working | Graphic cards | |||
| Reliability Monitor not working... | Vista performance & maintenance | |||
| Reliability Monitor Not Working | Vista performance & maintenance | |||
| Reliability Monitor not working? | Vista General | |||
| Widescreen TV not working as second monitor | Vista General | |||
