Go Back   Vista Forums > Vista Forums > Graphic cards
Vista - Resolution Problem
Old 07-05-2009   #1 (permalink)
Vista Home Premiun 32bit
Resolution Problem
I have installed New driver for Geforce 9600GT. But now I am not able to tune my resolution to 1440 * 900. the resolution either less than the normal I am using or more than that. My monitor is Wide screen 19'inch.
Can some one help me ......
Old 07-05-2009   #2 (permalink)
Windows XP x86 Professional Service Pack 3, Windows Vista Ultimate x86 Service Pack 2 (VMware)
Re: Resolution Problem
Were you able to set the resolution at 1440 X 900 before you updated your driver?
Have you tried updating your monitor's drivers?
Old 07-05-2009   #3 (permalink)
Yes .. I can able to set to 1440*900 previously but when I update the driver,all the resolution was changed.
I am using same driver for the Monitor ... there is no update for it.
Old 07-06-2009   #4 (permalink)
Try changing the refresh rate of your monitor to something lower. To do that, right click on your desktop then click on personalize. Then click display settings at the bottom. This will open up a display settings window. Click on advanced settings then click on the monitor tab. Try lowering the refresh rate to something lower. If that still doesn't allow you to set it at that resolution open the same window and untick the "Hide modes that this monitor cannot display. Be wary though and check the text written just below that as a warning. But since you were able to do that before it might work. Also, in case it doesn't and the monitor doesn't display just wait a few seconds and it will go back to normal. Hope this helps.
Old 07-07-2009   #5 (permalink)
Thanx this works for me
Old 07-07-2009   #6 (permalink)
Home Premium X64, not impressed with W7 RC yet...
Also worth mentioning for Nvidia owners, you can set custom resolutions in the Nvidia control panel if you switch the control panel to advanced configuration.
Name resolution problem Network & Sharing
Resolution problem Graphic cards
Resolution problem Vista performance & maintenance
Resolution problem Vista General
