Go Back   Vista Forums > Vista Forums > Graphic cards
Vista - Ati Radeon 3870x2 problem
Old 07-09-2009   #11 (permalink)
Vista Home Premium 64bit SP2
Re: Ati Radeon 3870x2 problem
Guru3D - Driver Sweeper
use that one , in SAFE MODE
uninstall drivers ,m reboot into safemode run driver sweeper , reboot then install new drivers
Old 07-09-2009   #12 (permalink)
Vista ultimate 64 bit SP2
that will work for you, i use your uninstaller for uninstalling stuff including drivers
Old 07-09-2009   #13 (permalink)
please keep us posted as to if it works for you or not
Old 08-04-2009   #14 (permalink)
Windows 7 Ultimate 64bit
Well iv tried everything.
Remove drivers,safe mode/driver cleaner,change slot on my mobo,
update bios,full format,tested in second pc etc.
The graphic card is dead,no warranty...
So i bought a new card,the GIGABYTE RADEON HD4870 GV-R487-512H-B 512MB PCI-E RETAIL
And with my new card i bought the CORSAIR DOMINATOR DDR2 4GB (2X2GB) PC2-8500 (1066MHZ) CL5 DUALCHANNEL KIT
In the end of the month i will buy and the 10000rpm WESTERN DIGITAL WD3000BLFS VELOCIRAPTOR 300GB SATA2 end thats it.
Btw did i have to change anything in my ga-x38-ds4 bios cause i insert the new ram?
Old 08-04-2009   #15 (permalink)
Vista Home Premium 32bit and Ubuntu 9.10 32bit
you shouldn't have to because of a ram change.... it should just be detected
Old 08-04-2009   #16 (permalink)
sorry to hear that your 3870x2 died, i love mine and have had it for little over a year which for me is a record
What a ATI Radeon Graphics driver problem ?? Graphic cards
ATI Radeon X1050 problem Vista hardware & devices
Mobility Radeon resolution problem Vista hardware & devices
Problem whit radeon Vista hardware & devices
Radeon X850 problem with RC2 Vista hardware & devices
